79 Leaking Steering Rack
Looking at a 79 with a "leaking steering rack". I don't yet know (and won't) until I get the car home as to what is leaking. So if I plan on a worst case scenario, which I believe would be a reman/ rebuild rack, what am I looking at for cost? I checked a few sponsors here and don't see rack assemblies, are they no longer available? As a DIY, how many hours would you guess? Anything that makes this a really difficult task?
Thanks!
Thanks!
Chronic Tool Dropper
Look at the 928 International website for a rebuilt rack. Last I looked they were about $400 exchange. The other major 928 parts vendors sell the 928 International rebuilt rack, so your choice of vendor probably falls to whichever place is closer to you. You'll want to ship or deliver your old rack to them, as the core charge is not cheap.
Talk to whomever you buy it from, for a list of the parts and pieces you'll want to include in your order. Those are typically tie rods and tie rod ends, the power steering hoses and a reservoir/filter. You may also want to include a steering shaft coupling, and rebuild kit for the pump. For sure you'll want to thoroughly flush whatever older parts you reuse, including the power steering fluid cooler loop if your car has one. I'm pretty sure new boots come with the rack, but best to verify when you buy.
928 International is where I checked but couldn't find a rack. Lots of parts to accompany one but no actual rack. This is why I thought perhaps no longer available. Maybe I'm not searching correctly?
Any thoughts on the magnitude of this job? Lots of labor hours or not to bad?
Team Owner
if you also swap in the PS tank ,
and short hose, it should take you about 3 hours or so with the car on 4 jack stands
The Parts Whisperer
Thank you, sir!
as we speak everything on our site is in stock. Would everyone prefer all items we offer are always on the site?
sorry but at the moment we were trying something different on our site. We have a batch of rebuilt rack arriving next week and they will be back on our site.
If you don't list it, people complain that it isn't available.
If you do list it, people complain that you are scamming them into ordering stuff that isn't there.
Am I the only one who understands that used parts is "sometimes it's there, sometimes it isn't" business? Yeah I know probably not, but it sure seems that way sometimes.
Regardless of whether or not it shows, a call or e-mail will very quickly establish if they have it in stock or expect it any time soon.
You can't win, can you?
The Parts Whisperer
Confirm it's the rack before ordering. Other common items are the reservoir, as Mr. Merlin stated, which is actually really cheap as I recall, and the high pressure hose. My car had developed a leak on the high pressure hose where the engine was rubbing the hose near the driver's side fender, but I also replaced the reservoir out of caution because they will crack as they get old.
The best option on the hose is to have it rebuilt at a local hydraulic shop. They will reuse the factory ends and make you a new hose, also pretty cheap as I recall.
Building on Chris's info, the reservoir includes the PS fluid filter as an integral part. These are regular maintenance items, and could probably deserve replacement with the auto trans service every 25k. The two hoses that connect to the reservoir get crispy with age, hardening to the point where maintaining a tight seal is impossible; You can't get enough clamping pressure on the hoses to restore the seal. One of the hoses feeds the power steering pump, the other comes back from the "steering fluid cooler", which on my car anyway is a loop of steel tubing on the floor in front of the AC condenser, runs laterally for the width of the condenser. All those screw-clamp connections eventually leak as the hoses harden and shrink. When they do, the fluid runs downhill and is blown back by airflow through the grill and radiator. It gets in and on the alternator cooling duct, then everything aft of that eventually gets soaked too.
Most cars seem to have the original reservoirs and filters, and many still have the original low-pressure hoses too. Replacing all of those isn't difficult, but it can be a little messy if you aren't careful catching the fluid. A Very Good Time to take on that hose-replacement task is when you have the system drained for motor mount replacement. Plus you are already doing all that cleaning underneath, when draining another 8oz of ATF is literally a drop in the bucket.
