AC hose installation questions
I need some help understanding the correct positioning of the flexible AC return hose that connects from the low-pressure return line into the compressor. Item 29 in the diagram below.
I removed my compressor to rebuild it. Re-installation and O-rings replacement required removing the hoses. Now re-installed, the hose is forced against the radiator shroud (This is a S4). Is that normal? I don't remember if it was before but there are marks on the hose to indicate it was. I'd appreciate any pics of the proper clearance. It's a difficult area to see.
Second question, I noticed that my hose offered some ability to swivel the top neck (see purple circled area). Is that correct? Seems like a place to leak.
I can only say it should not be touching the Fan Shroud, else you would have to remove the AC hose in order to remove the Fan shroud, and I have never had to do that.
Also I do not recall that part being a swivel, it is a pressed on crimp and the orientation is determined by whomever crimped it. IIRC that large hose connects to the Lo side AC pipe that is attached to the Fender, and that may be out of alignment???
Are these new stock hoses or did you have them re-done?
Received 1,542 Likes
You probably have the hose clocked wrong on the compressor manifold.
A/C hose neck should NOT swivel on the fitting.
Pic of hoses on compressor (6-cylinder ND through ‘89.)
Archive Gatekeeper
Hardline support bracket and tensioner bracket orientation:
Rebuilding hoses
I pulled the compressor and hoses out of the car and the clocking of the hoses looks to be correct compared to others. I think the interference of the large low side hose with the radiator shroud is more of an issue of the aftermarket radiator being wider by about half an inch. Also, the radiator shroud sets further out on this radiator and it would on the stock radiator. I think when I reinstall I will put a sacrificial wrapping around the low side hose.
As for the swiveling head on the low side hose I have confirmed that the hose is original. And thus the head is loose and will need to be rebuilt. So off to the HVAC folks to rebuild the houses and I’ll have them tested the compressor to to make sure I got all the seals in correctly
Is it an older aluminum Rad, the last two I purchased, the ones that 928 International and Roger sells were an exact fit, not thicker, I know some of the older ones were?
I also see that the Fan shroud tabs are not fitting into the slots on the bottom edge, looks like you have Zip Ties, that could be a factor too.
BUMP
I am having the same issue that Michael mentioned in first post: the orientation of the suction hose now is firmly against the cooling fan shroud. I have the original radiator and this was not
happening prior to removing compressor.
it is a MUST that the hoses attach to the compressor before the compressor is hoisted in place? it does not appear there is access to the fittings with any wrench, tool or spanner.
is it the function of this bracket to orient the hoses with compressor off the car? (this bracket is pre 1990, for 6 cylinder compressors)
Chronic Tool Dropper
BUMP
OK got it! that makes it all very clear. thanks
compressor is in place and now I need to know if there is a trick to threading the high side hose, past the radiator, to reconnect to the condenser?
Archive Gatekeeper
Undo the passenger side blockoff shield, screws are marked. The upper tapping screw may be reached from above if you position the headlight correctly, or from below with the headlight completely raised, through the right front wheelwell.
^^^^^ Thanks…...Found the lower screw with ease but not the upper. For the record, the cooling fans and radiator are in place; do they need to come out?
Removed the RH fender liner, along with the forward dust shield to expose the headlight. Looks like the upper screw is hidden behind the horns? I was able to wrestle out the hose with just a little tug. I don't suppose I can cheat and do the same with re install?
