928 Forum 1978-1995
Sponsored by: 928 Specialists
Radiator leak?
Old 01-28-2018, 08:04 PM
4W4K3
4W4K3's Avatar
Default Radiator leak?
Hey everyone. A couple weeks ago, I purchased an auto '85 928S. I've gone through one tank of gas so far with no issues, driving it almost everyday, while I make a list of things to address on the car. While filling up the second tank of gas, noticed a little puddle of coolant forming beneath the car. I took it home and didn't have any more leaks out in the drive way overnight. Today I rented a pressure tester from the local parts store, compressed the expansion tank to about 5 psi and found a small steam of coolant coming out of the passenger side top of the radiator.
So, I'm looking for a second opinion. I think the radiator's cracked, do you agree? If it is cracked here, is there much else to do aside from replace it?
Old 01-28-2018, 08:36 PM
ammonman
ammonman's Avatar
Typical leak point. The hottest coolant enters the rad through that hose. New tanks are available from the 928 vendors and there are a couple of good writeups here on how to replace them. I did both my end tanks almost 10 years ago and everything has been peaches since. THere is also a really nice replacement aluminum rad available from 928 International.
Old 01-28-2018, 09:09 PM
dhallford
dhallford's Avatar
Had the same issue last year. Wasted too much money trying to repair the original radiator, with no success. Finally bought a new aluminum radiator. No more radiator issues. Save time a frustrations, order a new one first thing tomorrow.
Old 01-28-2018, 09:38 PM
Gonzotiki_666
Gonzotiki_666's Avatar
Depending on your budget, replace w new 928 Int'l aluminum (~$500) or side tank w gasket (~$100) and have a radiator shop install it (another ~$150). I did option #2 and the rad shop recored my old Behr as well. No leaks & the temp gauge has been in the lower 1/3rd ever since.
Old 01-28-2018, 10:23 PM
4W4K3
4W4K3's Avatar
Thanks for the info guys. I'm leaning towards the aluminum replacement to avoid further frustration. When you say side tanks, is that referring to an additional section/separate component to the main radiator? Would those "tanks" be included as part of the replacement aluminum unit?
Old 01-28-2018, 10:41 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Default Tanks
FYI. Most tanks have not been available for a bit
Old 01-28-2018, 10:51 PM
4W4K3
4W4K3's Avatar
Any word on when they'll be in, Mark?
Old 01-29-2018, 12:59 AM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
DO you need new tanks to fix this, or just new seals only?
Old 01-29-2018, 01:06 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
the part thats damaged is the flange.
the plastic in this area is not covered by coolant as an airbubble is living in the top,
thus the plastic gets hot and flexes and the various combustion gases and other chemicals let the plastic work harden,
then it fractures along the top edge. a new seal and passenger end tank will usually restore operation,
best to let the Radiator shop replace the tank
Old 01-29-2018, 03:31 AM
Mrspencer
Mrspencer's Avatar
Just had my radiator done, 85 928s, had the side tanks removed and the radiator rodded, there was a ton of c4ap that came out wich is why the side tank seal gave out, the shop was surprised that the car never overheated, even with my side tank leaking , over 75% blockage, before cleaning, radiator is like new and stock.Mel and sons concord ca.
Old 01-29-2018, 10:12 AM
jeff spahn
jeff spahn's Avatar
You could call Roger and see if he has any new Behr rads. I got a new one from him. I am good for 20 years. My Al one only lasted 7
Old 01-29-2018, 12:32 PM
ROG100
Basic Sponsor
ROG100's Avatar
I wish the Behr rads were still available at circa $800. Even from Porsche I had to send 4 back under warranty due to leaks.
I sell the 928 Intl alloy radiator for $595 - I have three in stock.
Old 01-29-2018, 05:01 PM
4W4K3
4W4K3's Avatar
Thanks for the detailed explanation, Merlin. That really helps to put it into perspective.
So guys, it looks like I might try the tank/seal method first. Is this tank and seal a generic part that a radiator shop would be able to source? This would be my first time working with one on a job like this.
Old 01-29-2018, 06:04 PM
ROG100
Basic Sponsor
ROG100's Avatar
Just to echo what Mark at 928 Intl said - the tanks have become hard to find especially with the cooler holes.
They may be NLA from what I have been told by the radiator parts wholesalers.
Old 01-29-2018, 06:08 PM
Mark Anderson
The Parts Whisperer
We have just 2 tanks left and both are without cooler holes. I do believe you could use a hole saw and add them but no personal experience here
Quick Reply: Radiator leak?
