RB light weight 2pc big rotor kit for GTS
Former Vendor
Racingbrake is pleased to announce a big rotor kit with 340x32mm is now available here:
http://www.racingbrake.com/RB-Two-pi...p-9-p/2483.htm
This will allow GTS to oversize its' stock rotor from 322mm to the same size as the new 991 GTS @340mm, but still keep it at 32mm.
Rotors are built with RB's center-mount design discs for better cooling, made for track duty yet still lighter than stock size.
Availability: In stock.
Archive Gatekeeper
Got a pic of the spacers and the degree of caliper trimming necessary to fit these?
Former Vendor
That would be our next step to have all these configured. The idea is to offer an efficient brake upgrade, using the same pad, increasing the brake torque and thermal capacity, w/o excessive over-weight like 350x34mm (997 rotor upgrade kit), still save 3.5 lbs per rotor over 1pc OE and fits under 18" wheels.
