Oil pressure sensing gauge reading full scale - problem is...?
Really?
I did some testing last night. its pegged with the key on .. then, i tap 14pin connector (10 from the left) and it goes to zero. turn the key off, it goes to zero. turn the key on, it goes up a few mm...... start the car and it peggs to 5 bar.... turn the car off, and its stuck at 5bar..... tap the 14pin connector, and it falls back. did it a few times and its still pegging at start, but falls to zero after turning off.
oil pressure sensor?
sender wires look nice and covered. wires in good shape, connections good and tight. insulation good.
What about a test at the sensor? that way, if running , we see a specific voltage or resistance and can determine if it is good or not.
I did all the leg work and it all came back to a bad sender, even though the sender wasn't more then a year or two old.
http://www.lindseyracing.com/LR/Parts/944OILADAPT.html
i rigged my new sensor up with jumper wires to the factory wires as i sat in the seat...turned on the key..blew 60 PSI of air into the sensor...spot on 4 bar on the gauge....knew it was a good sensor as well as the gauge in the pod being accurate. Any issue from then on was wiring. Pull your old installed sensor out and do the same thing. (just dont strip the threads on the block)
Mark, this might be an option, it worked for me.
Sender, until proven otherwise seems to hold true. Chronicled in this "low pressure, high pucker" thread;
https://rennlist.com/forums/928-foru...essure-s3.html
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Captain Obvious
Super User
Super User
Yes, i am interested in logic... there is a logical explanation why a tapping can cause this seemingly capacitance like observation to occur. this doesnt seem like a bad connection. its more than likely the sensor itself. a few "logcial" tests should determine this.
yes, it all helps... by the way, i was mistaking the 14pin connector with the 10pin connections below the fuse and relay panel... where is the 14 piin connector? is that the ribbon connector under the hooded console on the dash ?
I had other issues giving me problems. Just suggesting that hopefully it's the sender giving you the wrong numbers on the cluster gauge.
where is the 14pin connector?
The 14 pin is the front engine harness to the fender well near the jump start post the harness that has the oil sending unit wires inside.....SO WHERE WERE YOU TAPPING ???
