928 Forum 1978-1995
Sponsored by: 928 Specialists
85/86 Passenger Side Ground Strap
Old 01-14-2018, 02:07 AM
nosnow
nosnow's Avatar
Default 85/86 Passenger Side Ground Strap
I am fixing my early 86 and need some help figuring out where the ground strap on the passenger side of the engine goes. It is currently missing so I am not sure the location. I believe it connects to the engine hook but not sure where it connects on the apron. The previous owner had some interesting repairs.
Old 01-14-2018, 03:26 AM
GT6ixer
GT6ixer's Avatar
I'm not sure on those years but on my '84 it is located on the side of the block and then goes over to the fender like is shown here....
https://rennlist.com/forums/928-foru...ml#post8213173
I imagine this is the same location on your car.
Old 01-14-2018, 03:29 AM
nosnow
nosnow's Avatar
Sorry I meant the ground strap on the passenger side head. I think it is specific to the 32 valve engines.
Old 01-14-2018, 10:03 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
This strap goes from the lifting hook to the coil securing bolt
Old 01-15-2018, 12:21 AM
skpyle
skpyle's Avatar
What Stan said...
These are from my 1986.5:
One end of ground cable goes under passenger's side coil bracket mounting screw.
Ground cable loops up and behind harness.
Other end of ground cable goes to the lifting eye on the passenger's side cylinder head.
Eye of ground cable terminal goes under P-clip for harness on lifting eye.
Old 01-15-2018, 01:20 AM
nosnow
nosnow's Avatar
Thank you. The pictures really help.
Old 01-15-2018, 01:26 AM
skpyle
skpyle's Avatar
You are quite welcome!
Quick Reply: 85/86 Passenger Side Ground Strap
