As promised...maint. records and the beginning of my plan attached
Both documents attached. The only real symptoms the car is giving me thus far is the coolant leak at the water bridge (same as Dwayne had), a leak where the transmission cooler lines join the radiator, and the power steering hoses are leaking (seeping would probably be a better word as there are no drips). There are also a couple of electrical gremlins that I think are related to fuses (mentioned in initial post when I introduced the car to the board). Other than that it runs well, idles smooth and makes no weird noises or ticks. I've attached an excel file with the history and a word doc with my initial plan. Please feel free to comment and make suggestions. It is my intent to do most of this myself. I will probably farm out the check of the flex plate as this may be above my pay grade. The other thing I'm not totally sure on is the rebuilding of the transmission cooler hoses and the fuel lines. Thanks in advance for any suggestions and guidance
Received 1,207 Likes
I think this is a follow up on this thread.
Right?
If so, maybe ask the moderator to move it.
Nice car.
https://rennlist.com/forums/928-foru...ck-answer.html
Right?
Nice car.
