928 Forum 1978-1995
Sponsored by: 928 Specialists
Factory paint question
Old 01-10-2018, 07:28 PM
drscottsmith
drscottsmith's Avatar
Default Factory paint question
All -
what is the sequence and color of factory paint application of my 1983 s?
see pic below, but it appears to have a dark gray layer applied to the metal, followed by a very light gray, followed by a medium gray, then the base color (in this case kiln red).
this is the sunroof panel out of the car.
thanks -
​​​​​​—scott
Old 01-10-2018, 08:31 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
The first layer is an electric dip primer, then a polyester filler, then paint- single stage for solid colors, two stage for metallics.
Old 01-10-2018, 08:46 PM
drscottsmith
Thanks Rob -
which layer yer do I want to “keep” when sanding Down for paint prep?
i honestly thought the car had been resprayed at some point, and my plan was to take off all of the respray, but that could just be certain panels and not the entire car. I have only test sanded that sunroof panel.
there are definitely not two different base (red) layers on the car.
i do suppose the car could originally have been gray (the “third” layer up), but that would mean under hood, door jambs, etc would all have been painted.
i have no options sticker or door jamb paint sticker to verify factory color.
-Scott
Old 01-10-2018, 11:03 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Scott--
For sure you'd love to maintain that base layer especially on the aluminum stuff.
Share the VIN on the VIN search thread here and find details like the original color.
Old 01-11-2018, 03:22 AM
The Forgotten On
The Forgotten On's Avatar
The base coat is the hot dip galvanizing coating. Remove the paint with paint stripper (aircraft paint stripper is aluminum safe).
It will eat through the paint and not damage the galvanizing. Neutralize it with mineral spirits after you have scraped off the paint.
Sanding can be a bit iffy on how deep you cut the coatings.
Old 01-11-2018, 05:31 PM
drscottsmith
Thanks all -
Mine is an early '83, so when Rob ran the VIN for me there is no color information. I may try to go through the local dealer and see what kind of response I can get. My car only has one "strange" option
I will take a look at some other panels this weekend and sand a bit off just to see if I can find the suspect "two layers of kiln red".
Will report back. I am still unsure why I have three distinct shades of gray on that sunroof panel underneath the kiln red basecoat.
-scott
Old 01-11-2018, 05:54 PM
Rob Edwards
Archive Gatekeeper
If you want to geek out on the primers, fillers and paint used in period, here's a PDF of the factory guide on materials for repairing damaged paint, from the Morehouse CD's. Published in 1983, appropriately:
https://webfiles.uci.edu/redwards/pu...0on%20Cars.pdf
Old 01-12-2018, 09:33 AM
drscottsmith
Default New pics
So I did a little sanding on the driver's side tonight to see what I could find. Pics below.
The B-pillar panel looks like it is still factory - although I had to go pretty far down to get to the white (can't find other layers though).
The door tells the story of the repaint. I finally found a second layer of red underneath. Still kind of odd, but looks like there is a sealer/primer on under the top color coat, then the original red followed by the same sequence I see on the sunroof panel.
This also might explain the subtle difference in hardware I found on the inside of the door panel on dissassembly. On the passenger side door, the round "lock-unlock" dial is held down by a nut on a threaded rod. On the driver's side, the dial is held in by a philips-head machine screw. Any way to reconcile the difference? I assume that means the door could have been replaced at some point in the car's life, but interesting that they were able to get a door (if that's what happened) in the same color or close to it.
Any other thoughts?
B-pillar - that white spot is awful soft in the middle - bondo perhaps? coincidental that I randomly chose that spot to test sand
Door - aha! two layers of red!
Old 01-12-2018, 08:06 PM
jpitman2
jpitman2's Avatar
Re the doors - are the speaker depressions the same on the doors? The hollow on the left door looks to be in a different location to that on my 83(jan) car.
jp 83 Euro S AT 57k
Quick Reply: Factory paint question
