Mahle or Mann or is there a Synthetic Oil Filter yet?
#32
I will only sell Mann as they are OEM to Porsche.
Mahle are not OEM and considered aftermarket in my book. Not saying that is a bad thing but most of my customers want OEM where possible.
I am not arguing which is better but if it is good enough for Porsche it is right for my customers so I sell OEM Mann.
We sell the OEM Mann for $8.95 and it comes with the drain plug sealing ring.
I also sell plenty of the Red Porsche oil filters which are made by Purolater for $12 and they also come with the sealing ring.
I struggle to see a problem that needs a solution when we have a solution that has no problems for 9 bucks.
That is not to say that oil filtration cannot be improved - I just do not see a need for such- either way good luck to the OP with the quest- there are always things to learn.
#35
I don't think this would be an issue, as the oil bypass valve should handle this scenario.
#37
Really, that's the worst time, when any unfiltered sediment or particles have settled to the bottom of the pan right below the pickup.
#39
Really, the fact is that there is no filtered oil running through the engine since as soon as it leaves the filter and touches anything it is contaminated and then gets worse as it runs through the engine back to the filter. It is pretty much like buying a new car. No one drives a new car since everyone is driving a used car. It becomes a used car the moment it leaves the showroom floor, or maybe even the moment it leaves the assembly line.
#42
