Climate Control Problems
I have a 87 s4 that I have been bringing back to life. I can't get the climate fan to come on. There is no power to the switch or the blower and I by passed the blower and it runs fine with 12 volts applied. When I move the slide on the controller I hear noise from under the dash, it sounds like a electric motor trying to move something but I can't identify it. When I put it on defrost I see the blend door moving to divert air to the upper vents. I have check fuses and relay but just haven't had any luck. Sorry if it sounds like I'm rambling here, late night at a new years eve party.
Team Owner
replace the blower fan relay
Team Owner
replace the HVAC relay and then the X bus relay do one at a time
