Manual transmission/axle fluid
I have searched and read many posts about correct or "best" fluid for manual transmission and axle and
not sure I understand. currently, transmission shifts great and the feel is wonderful; its just time to change the fluid I have on the shelf plenty of Redline 75W-90 and have used that in many cars with great results, but I keep reading about Redline 75W-90NS non slip formula. most of what I have read suggests using the NS in older pre 1985 boxes. is the non slip fluid for my 90GT 5 speed with PSD, or should I stick with the standard stuff FWIW: I live in florida and its hot year round!? |
No friction modifier is specified for the fluid in PSD equipped boxes. Use a good synthetic 90W or 75-90W standard fluid, not an "LS" fluid.
Mike |
Make sure you use a "GL-5" fluid, not a "GL-4".
Still not sure about type of fluid to use: Motorsports sells a trans change kit that includes Redline 75W-90,
but on the Redline website here is the description for that oil:
that seems to suggest this is not for 928 5 speeds with PSD? |
Mobil 1 75W-90 Synthetic Gear Lube. It is labeled "LS" gear but works very well with both mechanical limited-slips as well as PSDs. Much better than Redline in my experience, especially when cold.
FWIW: just spoke with technical support at Redline who said DO NOT USE their 75W-90 gear oil in 928 transaxle.
the correct recommended oil is 75W-90NS which means non slip. here is specs from their website:
Excellent, glad that's solved.
Going to have to order me some.. Need to do that myself.
Originally Posted by jcorenman
(Post 14704140)
https://rennlist.com/forums/928-foru...ce-or-not.html My leak has been reduced to a seep and no longer shows up on the garage floor. Further, the tranny shifts fine and PSD works as advertised. |
[QUOTEI was running Red Line and had a front seal leak][/QUOTE]
George, which Redline product were you using? |
75W90 NS
Transmission Seal Leak with Redline NS
Interesting about seal leak. When I took delivery of my 89GT three years ago, it can fresh with new fluids including Redline 75W-90 NS. It too has developed a leak leaving spots on the garage floor and grimy transmission case. I have been thinking about giving it a shot of ATP AT-205 Re-Seal. Anybody tried this?
Originally Posted by merchauser
(Post 14705110)
Having said that, although I currently run Redline in my 84 I do get some occasional drips at the front seal which I had resealed a couple years ago when I had the transmission apart. So I do plan to follow some of the other examples here and give the M1 75W-90 a try. |
... and LS is generally available. Got mine at Advance Auto down the street.
Does the fluid recommendation change if you don't have a LSD? My 5 speed 84 has an open diff...
