83 Cam Cover Removal
Hi guys,
I have an 83 S that I am trying to remove the head on (to ascertain damage from a dropped valve), I have all the cam cover bolts out and timing belt off, but it wont budge!
Is there any safe way to pry the cover loose?
Adam
Adam
Team Owner
post a picture of what your working on please
Ok, now I feel really stupid!! I counted the number of bolts removed against what should be there, somehow and extra bolt got in my counted lot... Grrr!
Of course it was the hardest one to get out in-situ! Cover has come loose a little but still needs some "encouragement", will look again later...
Thanks guys
Thanks guys
Administrator - "Tyson"
I should add that the engine is still in the car, trying to remove now to try and get a handle on the full extent of the damage to help decide what to do next..... (hence why I missed one bolt...)
Cheers
Adam
Good luck. Those two dowel pins can be a very tight fit.
I should really have a dead blow hammer for stuff like this.
