928 Forum 1978-1995
Sponsored by: 928 Specialists
Early ABS sensor fix by Committee/928 Community
Old 02-12-2018, 02:21 PM
  #31
KenRudd
KenRudd's Avatar
I also looked at the AIM sensor, but it appear too narrow, based on the drawing ( Diameter looks to be 15mm). However, appears to be made by Honeywell, so that may be another lead for sensors.:
Old 02-12-2018, 02:24 PM
  #32
KenRudd
KenRudd's Avatar
The Bosch Catalog tells us nothing we don't already know, it is unavailable and they do not spec an alternate:
Old 02-12-2018, 02:26 PM
  #33
KenRudd
KenRudd's Avatar
Old 02-12-2018, 08:22 PM
  #34
928wolf
928wolf's Avatar
It looks like that drawing says the diameter is 17.90 mm, which looks pretty darn close.
Old 02-12-2018, 08:59 PM
  #35
KenRudd
KenRudd's Avatar
You are right. I was reading the R12 below and to the right as radius, but that is wrong. Good catch.
Old 02-13-2018, 04:30 PM
  #36
dr bob
Chronic Tool Dropper
dr bob's Avatar
I haven't had a finger on the pulse of this thread, buts just read through it. Instant thought: Beware trying to "machine" the center pin. They tend to be sintered rather than a cast, extruded or forged part, and need a lot of care especially if you decide to adjust the shape. The risk is that there will be a fracture up higher inside the plastic shell. You won't see it, and the piece will will no longer function. The coil will still show correct Ohms so no apparent reason for not working. Impact damage seems to be a primary killer of the sensors. It used to be from accidental contact/impact with the toothed ring, but maybe that's better these days. Cable and connector damage is similarly popular.
Old 02-13-2018, 05:10 PM
  #37
KenRudd
KenRudd's Avatar
Still too short though. OE Rear ABS Length is about 46.75mm. AIM Length 31.8 mm.
For an induction sensor, I think that is way too much of a difference.
Old 02-16-2018, 01:32 PM
  #38
928wolf
928wolf's Avatar
Originally Posted by ROG100
Had time to look at this further.
Dealing with the rear sensors first.
I have found an alternative that seems in good supply. However a few questions.
Diameter is the same - bolt location is the same - the top plastc round section with the O ring is smaller but fits. A larger O ring should solve this issue.
Two wire - black and brown so that should make connection easy.
So the problem is length. The small section of metal at the bottom is about 10 mm too long. This is the magnetic part.
Seems solid material. Can this be cut down in length by 10 mm and still work?
Coming back to this option, couldn't you just shim it 10 mm instead of machining it down (with all the problems that entails)? There isn't unlimited space in that area, but 10 mm doesn't seem like that much.
Thoughts?
Old 02-16-2018, 03:12 PM
  #39
dr bob
dr bob's Avatar
In the picture above -- is the tip broken off the lower sensor? translated: Is the bottom picture a damaged version of the new top one?
Old 02-16-2018, 03:47 PM
  #40
soontobered84
soontobered84's Avatar
Dr. Bob,
The bottom sensor is what the 928 sensor looks like. The upper sensor is from another car.
My question would be: could the new sensor be taken apart to machine or swap the tip to the shorter version and decrease the opportunity to damage any other part of the sensor?
Old 02-16-2018, 08:59 PM
  #41
928wolf
928wolf's Avatar
No, that is the way it is supposed to look. That's the rear sensor. The front looks a lot closer to the "new" part in the picture.
Old 02-17-2018, 01:23 PM
  #42
928wolf
928wolf's Avatar
Also, does anybody have a pin out diagram for the ABS controller unit and connector? The wiring diagram in the WSM doesn't exactly achieve what I need - which is to identify the 2 pins that correspond to each of the 4 wheel sensors and measure resistance and voltage.
A bonus question: there doesn't appear to be a steering wheel input to the system. Is that correct? I think most modern cars use that to determine the differential in wheel slip due to turning.
Thanks in advance.
Old 02-17-2018, 07:58 PM
  #43
928wolf
928wolf's Avatar
Thanks in advance.
OK, found it myself if anybody needs it.
Old 02-21-2018, 01:21 PM
  #44
KenRudd
KenRudd's Avatar
Leveraging the miracle of Amazon Prime's liberal return policies and huge inventory, I ordered several ABS sensors that looked like they _might_ be useful in our search. I will test and report back.
Old 02-21-2018, 07:59 PM
  #45
928wolf
928wolf's Avatar
Excellent, I'm excited to see the results. It looks like I am in need of 2 rear replacement sensors.
Quick Reply: Early ABS sensor fix by Committee/928 Community
