928 Forum 1978-1995
Sponsored by: 928 Specialists
Lazy Voltmeter - Reads low
Old 12-03-2017, 11:41 AM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default Lazy Voltmeter - Reads low
1990 S4 105k
Newly installed SeanR built front harness.
Voltage at battery engine running 14+ volts.
Gauge reports 12v on startup and may increase to 12.25v after driving a bit. Or not.
Voltmeter does not react to the blinkers. But, if you turn the lights on the voltmeter will show an increase in voltage - maybe a half a volt to 12.5v.
That last bit I have never seen before.
Ideas? I will start to look at grounds.
Old 12-03-2017, 02:01 PM
928Myles
928Myles's Avatar
Kevin,
exactly what my voltmeter has done ever since I took the pod out the first time to clean all the connections and replace a few bulbs. I have had the pod out several times since to try to fix it but with no luck yet.
Grounds have been cleaned multiple times since to no avail.
Sorry not much help but eager to see if you find a fix.
Myles
Old 12-03-2017, 02:20 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Were also missing corrosion/resistance in the voltmeter pot that adjusts/calibrates it.
It's also a dirty exposed part of the circuit as well...exercise it with corrosion cleaner when it's out.
Couple of vids of it here, and adjusting it.
(Yes, i called it a regulator by accident)
Old 12-04-2017, 04:46 PM
Snowglobe
Snowglobe's Avatar
Thank you speedtoys
Old 12-04-2017, 05:13 PM
Kevin in Atlanta
Originally Posted by 928Myles
Kevin,
Myles
What I wonder ( and I am no electrical genius ) is if turning the lights uses a different ground and therefore a higher voltage reading. Maybe Alan could chime in.
Old 12-04-2017, 09:34 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Consider that with headlights on, the voltage to the dash illumination actually decreases. You have a leak or crossed connection between illumination and voltage sense. My too sense.
Old 12-04-2017, 11:32 PM
Kevin in Atlanta
Not sure this is related, but my gas gauge also is misbehaving. I reads 1/2 full all the time.
Old 12-04-2017, 11:44 PM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Originally Posted by Kevin in Atlanta
...reads 1/2 full all the time.
That's pretty darn annoying. But it could be a lot worse and show 1/2 empty.
Old 12-05-2017, 09:18 AM
Kevin in Atlanta
I am grateful for that.
Quick Reply: Lazy Voltmeter - Reads low
