Just bought a 84 928 auto have a few questions
Am not seeing anything out of the ordinary. The pins I think are for factory tool to read timing, don' see where they are hitting anything. Unlikely for 84 to suffer from thrust bearing failure. To check tt bearings, disconnect back coupler too and feel it when you spin by hand. Constantine is best guy to comment further, I'd use his superbearings if tt Bearings are reqd
Also, can hookup exhaust and run motor with tt disconnected to evaluate for engine or accessories noise. Also, you can take a hard look at rear axles, a common area for wear issues.
I see clearance cuts made for the pins and no evidence of any scraping. Its old corrosion. Where do you see current contact?
Not seeing bent over pins. (is it me?)
Will pull out some old pictures tonight to see if I can show same on my car....been so long my memory is foggy.
Does anybody else have pics of 84 auto flywheel to corroborate???
Team Owner
nothing to see here, it looks normal,
the pins are for the aft trigger sensor to read the timing at the dealer,
the cutouts are machined into the bell housing .
scraping the top of the bellhousing
relationship of flex plate and the scraping
can you see anything unusual in this shot of the bearing
Team Owner
tap the pin back straight, it will only serve as a balance weight for the flywheel at this point.
The TT bearing looks original and thats dried grease on its seals probably time to replace the bearings.
I would consider Constantine's bearings as they are much stronger than the originals
Chronic Tool Dropper
Look carefully at the drive flange at the torque converter end. You'll have it out for the converter housing bearings. Loose rivets there get replaced with hardened bolts to solve rattling and vibration problems.
