Carl's new Intake vs AMV8 project intake (pros and cons)Discussion
#91
Rainman
944S2 intake manifold has all the same bolt locations.
only difference is the "middle" bolt - it's in a different spot on the S2 intake vs the 928 head, shouldn't be an issue with the other 4 securely down.
#92
Rainman
944S2 intake manifold has all the same bolt locations, plus a few more not present on 928.
this is a 944S2 gasket mounted on a plate that matches a 928S3 head (same bolt locations as 928S4 head)
#93
This must be the engine with the coated pistons in the "changed Alusil process" which loose the coating when it gets cold and gall in the cylinder that I've heard so much about?
Appropriately named Locasil?
Seemed like such a great idea to take the perfected Alusil process with iron plated pistons that has worked for over 40 years and change it.....
I'm hoping this saved them a few dollars on each piston/cylinder.
Engineering Department or the Bean Counters hard at work?
Which brings up the question of how many years has it been since the great German engineering firm of Porsche has built an engine that would last as long as a small block Chevy or a Toyota?
Planned obselesence or simply ignorance?
It is odd that they would change something so great and reliable like Alusil to save a few bucks. I personally think the bean counters took over from the engineers in 1995 but I digress
I personally think the last good engine Porsche made for any car really was the Mezger platform used in all GT models and turbos from the 996 up to the 997.2. Shame they stopped making it.
#96
Administrator - "Tyson"
Audi variable length intake manifold:
#97
Not all the 997.2 had it either. Last Mezgers were in the 2009 Turbo (which is why I have one) and the 997.2 GT3, the last Mezger engined GT3. A production, non turbo, non GT3 911 has not had a Mezger engine since the 993.
#98
Last I knew cylinder galling is a huge issue with Cayennes as well.
#99
Chronic Tool Dropper
The reason for the change in iron plated pistons had nothing to do with the bean counters - it is to do with the environment. Iron plating has been banned on environmental grounds as the process is extremely poisonous. New pistons have plastic coating, which wears out under certain conditions and scores the bores. Similar reason, why you cannot find anyone in Europe to plate or re-plate fasteners (nuts and bolts) with cadmium. Unless you can prove your link to the aircraft industry...
Meanwhile.... Mark, how's the A-M intake coming along?
#100
how did car transition the rectangular runners of his intake to the S4 heads? (or the hans adapters)
#101
Captain Obvious
Super User
Super User
In the mid 90's there was an aftermarket company (XB...something) that made variable adjusting runner intakes for Mustangs. The intake looked a lot like the early 32V intakes ('85-'86) and I think it was vacuum operated. The variable system was in the side "tanks" of the intake. It was a plate that moved back and forth controlling the volume of the side "tanks". I can't find any pictures probably because I don't remember the exact name. It would be an interesting project to graft one of them on a 928.
#102
944S2 intake compared to AMV8 intake and S4 template
it looks like there is a lot of material to work with, using the 944S2 intake. sure, it is a little off at the port face, but the legs are actually less round than the S4 , at the runner, which actually works out well , because it resembles the shape of the AMV8 intake runners after the port.
Im wondering if we can use the 944 runner , cut it at the base and angle the #1 and #4 area and weld it to the AmV8 intake runner as it enters the plennum area.
#103
and here is a picture of the curves of the runners... its looking like its better than i first thought using the 944S2 intake.
#104
Rainman
You see why there's no point chopping up the am intake?
think about the one thing you love about the am intake-- the runner design. That will get totally ruined trying to hack 944 runners to match the am bore spacing to the 928...
#105
what i see, is runners with the correct angle, but a side angle will be introduced by a cut at the base, ( and re weld) and an appropriate cut at the mating point with a weld . the welder will have to use the artistry to make the upper transition point work. Sure, there will be some turbulence, but the opening size and inlets should much more than make up for the losses.we can always flow bench it when it is done and i guarantee it will be night and day vs the S4 intake and probably near equal to what we have seen so far. maybe not the Carl's intake, as that thing looks like a beast!
