Clutch Slave Cylinder Rebuild
To me 22.2 mm is .001" away from 7/8" - take the old piston and cup to a brake shop and I bet they can help you .....Most hydraulic cups in my experience have a size moulded on them, as do many of the actual slave cylinders, and masters.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
See this old thread from 2009......https://rennlist.com/forums/928-foru...der-seals.html
Roger indicates kits are all same part no, but actual slaves are different part nos - is that different push rods, not a diameter change?
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
Team Owner
See my thread 88 5speed dropped in my lap it has pictures of the S4 slave vs the 86 slave the S4 slave also has a longer body this may be needed so the maximum travel of the clutch can be used the 86 body might work for this but it’s hard to tell without precision measuring of individual assemblies
I contacted a hydraulic shop yesterday to see if they could find me a seal, they said they don’t deal with anything that uses brake fluid and that the seal composition must be made specifically for that. Sounds fishy to me but they’re the experts and I don’t want the clutch slave to start leaking a year down the road.
As Roger said, he’s going t send an 83-86 slave cylinder to me, I’ll take some measurements and see if i use some combination of parts to build a suitable replacement of the same length and travel. Seems like the only part in the rebuild kit that doesn’t fit is the seal, and it is just slightly larger. I’ll take some pictures and do a writeup when Roger’s care package arrives.
I’ll peruse the seals catalog when I have some time, if they list brake fluid compatibility and have the correct size, heck, maybe a <$5 (shipped) option can be found!
Failing that, I’ll contact the Whitepost Restorations listed above by Merchauser to see what they can do.
I had no idea that the genuine slave was $500, but since you can get a slave made by FTE for $100, and they are relatively easy to replace, is there any reason why you wouldn't fit one?
I fitted one to my car over five years ago with no problems at all, although how I came to replace it is a story in itself.
https://rennlist.com/forums/928-foru...ands-trip.html
Don't get me wrong, I am all for using repair kits, I used one on my clutch master.
Basic Sponsor
UKKid35 - that is the main issue the FTE slaves are NLA so we are stuck with the $500 variety.
Team Owner
I sent FTE a E note asking them to make more of the S4 slave cylinders but never got a response,
maybe it went to the wrong address
Administrator - "Tyson"
My care package from Roger arrived last night, I don't think cannibalizing parts from an 83-86 is going to work. As previously mentioned, the body is shorter and my measurements indicate 10mm less travel on the 83-86 compared to the 87-(95?). The push rod looks to be a slightly larger diameter and quite a bit shorter, regardless I'm pretty sure I could swap the later, longer rod into place judging by the snugness of the boot that came from the rebuild kit. Bascially, it looks like the only thing that doesn't work from the rebuild kit is the seal. I called EPM (the "Seal Man"), whose document is linked above and am going to send him pictures and measurements. If he can source a properly fitting seal, I think combining the 83-86 rebuild kit with that seal might turn out to solve this issue.
I contacted WhitePost, they charge $175 for a resleeve and rebuild with a lifetime warranty. Since my cylinder is in pretty good condition, and really just missing a $3 seal, I'm going to try that route first.
Like everyone else, I would be very grateful indeed for a foolproof way to order new slave seals
So please keep us informed of your progress
If that means we order from you because you have taken the plunge and have 100s stored in your garage, then make sure you don't loose any money, and please let us order from you
Many thanks - Paul
Many thanks - Paul
Just an update, I have contact EPM (linked above) and talked with them a bit, they told me to get them some measurements and they'd be happy to help. I don't see any measurements on my slave cylinder piston and the button battery in my micrometer is dead. Ordered batteries and will measure, photograph, and send to him by the weekend. I'll have him send several sizes then see which fits best. I'll ask the hydraulic shop to pressure test it to ensure it doesn't leak. Hopefully we'll have a part number for a seal soon which, combined with the early rebuild kit will make it easier to rebuild a later slave.
I send this diagram off to EPM last night after measuring the slave cylinder piston as carefully as possible. I also disassembled the "burner" 83-86 slave that Roger sent me to measure the piston from that. The 83-86 is .9330" in diameter vs the .8685" diameter of the later piston.
