How best to reinforce the front sway bar mounts?
Does anyone have a picture of how they boxed the mount?
Developer
The only way to "fix" this area is to "box" in the mount and add thicker metal to the plate where the sway bar sway bar actually attaches.
I'm usually 5% smarter than stamped metal but I didn't look at the picture closely. Yes, the nuts got ripped out. Most of the time the bracket gets ripped off the body.
Looks like the full improvement is to reinforce both. The nuts seem a challenge.
Chronic Tool Dropper
Were I doing this mod from scratch without any consideration for maintaining originality... I'd make or find a piece of channel that would slip over the "frame" section. The old mount would come off completely. The channel sections would then get welded horizontally to the sides of the "frame" section. The channel would be drilled, and I'd add a steel strap that would slide inside, nuts welded over holes to accept bolts from the bracket. In the factory configuration, the load on the bracket has the bolts in shear loading, so moving everything horizontal would change that to tension only, hence the plate in the channel pieces to spread the load. Option: Slots or multiple holes in the channel would allow one to offer easy link alignment using a bar with several holes in the arms so the anti-roll could be "tunable".. Adjusting the height of the channel would also allow a straight bar such as the one Carl offers to clear the sump and starter a little more easily. A little creative engineering would allow for an additional lower cross-member for frame/tub support, bolting to the same channel sections on the "frame". Thinking "inside the box", so to speak.
https://www.flickr.com/photos/288046.../shares/xp1w22
We added metal to the nut, and welded the nut more too, factory just spot welds it.
Ive had on a stock bar, the nuts come loose..so this nut came lose and ripped out.
