Okay new 82 928 owner again parasitic battery draw
Okay new owner I have a parasitic 13v .05 amp draw that kill's the battery in 2 days. I've pulled every fuse and every relay and every cable bundle plug on the CE and it persists.The only time it stops is when I pull the heavy gauge wires (red) (3 of them) then the draw stops. Frustrating.
Are you sure it's 0.05A which is 50mA so a little high but not enough to drain good battery in 2 days. Total drain 2.4AH and capacity at least 50AH. Either your battery dead, or is drain 0.5A?
Chronic Tool Dropper
Gomez --
Put the year of your car in every post please. Different years have slightly different electrics and therefore different most-likely-causes. Please.
Membership lets you add a signature line with this and other information. Worth it just in the saved typing, IMHO.
