928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine R&R
Old 10-16-2017, 06:04 PM
pjmcgnns
pjmcgnns's Avatar
Default Engine R&R
Its a messy job!
Old 10-16-2017, 06:13 PM
soontobered84
soontobered84's Avatar
What is your plan for your engine? In other words, how deep into the abyss are you willing to go?
Old 10-16-2017, 07:08 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,237 Likes on 1,238 Posts
remove the fuel pressure gauge its of no use when the engine is running, and can cause a fire.
Goodluck withe the restoration,
FWIW having both belts pulling the crank pulley to one side will cause additional wear on the front main bearing.
NOTE this will be evident when the girdle is split
Old 10-16-2017, 08:11 PM
StratfordShark
StratfordShark's Avatar
Does same bearing wear occur when the air pump belt removed, but AC belt still on? If so that's a concern - I have air pump belt off just now, but I know some people remove all the air injection parts!
Old 10-16-2017, 08:33 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Originally Posted by pjmcgnns
Its a messy job!
Search for work gloves with longer cuffs?
Old 10-16-2017, 10:57 PM
granprixweiss928
granprixweiss928's Avatar
thats why I usually would steam clean the whole thing first. Makes the job way more pleasant.
Have fun cleaning!
Old 10-17-2017, 03:05 AM
dr bob
dr bob's Avatar
Have fun cleaning!
The engine as it hangs looks like it's already enjoyed a lot of cleaning. As many know, getting 97.3% of the easy/obvious cleaning done means there's only another 90% of the cleaning left to do after tth engine is actually out of the way.
I think the work glove gauntlets will need to reach all the way up the arm and cover the shoulders and most of the head. Some coverage duplication will happen but that's not a bad thing really. Just leave eye holes.
Cleaning seems to take at least as much time as "actual work" on any given projects. According to my "keep everything spotless" continuous-improvement program, I should have been able to white-glove the MM/OPG effort a year ago. In my dreams... I let my shop apron gather and store the small amount of remaining crud. Still ended up looking similar to the OP's picture, but with formerly-white hair and all.
Quick Reply: Engine R&R
