Headlight conversion kits
What do you guys recommend for converting the early sealed headlights setup to something brighter? Any particular kits?
Also, how would one go about reconnecting a headlight adjustment **** in a euro?
Under the Lift
Easy conversion is 7" H4's like Hella's. Plug right in and inexpensive. Better is the 8" late model H4's that came on the Euro cars. I did that in my 89 and like the improved light pattern. They will fit the early cars with the trim ring removed. New, they are quite expensive at $250 each from 928 International. There are some HID kits that vary greatly in quality. I've debated trying one of the better (expensive) ones but haven't and don't know anyone who has. Not sure how well HID would work with H4 reflectors. The H4's running 80/100 halogens are great, and the higher wattage hasn't caused any problem at all. I have a webpage on how I did the conversion in my 89.
http://www.billsworkshop.com/P928S4/h5toh4/h5toh4.htm
Range Master
Pepsie Lite
Pepsie Lite
Bill, I read the interesting story on your web site about the rubber on your shop floor. That experience would disinclined me to let my bride within 100 yards of anything mechanical that I valued.
I would build her her own garage (with "blow out walls", as far away from my "stuff" as possible, and I would buy her something indestructable for transportation. But that is just me.........
Funny story
Funny story
Bill, As entertaining as your story is re. 'the rubber strip', I'm certain it could be eclipsed by the driver's account: imagine the adrenelin rush of full throttle for 3 sec as your panorama explodes from tool chest to swimming pool! Back wall top hinged - in case of a sequel?
Humour is easy when everyone is safe!!
Chris, if your '78 is a euro, doesn't it already have H4 wiring? (some early sealed beam 'federalization'conversions were just plug- ins, possibly with an adapter plug because of different pin assignments [or that may have been on the 4"x6" H4's]) Assuming that you already have the correct plugs, you can't beat 7" H4's for the price/performance. The 'look' demands the 8" units, although I'm not convinced they perform any better.
Administrator - "Tyson"
I myself had 7" H4's on my '79 US spec. Continued to experience "problems" with state inspection stations from time to time, as well as the State trooper who lives right down the street from me. He took it upon himself to "remind" me that these were illegal in the Commonwealth of Virginia. So, I purchased the 8" H5's with new pigtails from 928intl. About $550 and same amount of light IMHO. Just don't have the crisp lines that the H4's cut into the night. All in all I'm more than satisfied. This has also given "The Man" one less thing to worry himself about!!
Thanks for the input guys! I suppose I'll be looking for some 7" H4's then. I take it they're much brighter (with the 80/100's) than the sealed beams and can use the same wiring? Cool... that's ideal.
My problem is there are tons of deer around this area and it's hard to drive with confidence when you can only see about 10 ft in front of your car.
I'd go for the 8" Euros but I dont know about paying $500 dollars to upgrade right now. Maybe I could spring for 1 now, 1 later and just aim the brighter one towards the middle for a while ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
And what about the headlight adjustment ****? Anyone had any experience with reconnecting it? I guess it would help if I knew exactly how that system worked in the first place
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
There's motors in the headlamps that adjust the angle. I was looking at the parts diagram last night. It was late, but I remember seeing something about a motor in there. I'm sure 928Int'l has them.
Speaking of deer, I've been wondering if those deer alerts work. Thanks for bringing that up. I should post a question for people. But how would one know? I guess if they never hit a deer, they might be working....
Under the Lift
Originally posted by Hacker-Pschorr
These kits were banned from being imported anymore. I had a talk with a few vendors at SEMA about this. The law passed just before the show. CATZ makes a very good system if you can find one. They are still out there just harder to find. The only way I think they are still legal is if they were an option on the car from the factory.
Under the Lift
Under the Lift
Search the Net (even eBay) for 7" Hella H4 headlamps. I have seen them for $45 each. Get some 80/100 watt bulbs (known as off-road only). Aim them properly. Do not aim them high. The top cut-off should be 3" below horizontal at 25 feet. The lighting improvement should be dramatic.
Under the Lift
And yes, the H4 bulb is a direct plug into the harness for the early cars with their sealed beams. All he needs if the 7" Hella lamps to put the bulb in.
Under the Lift
Some 7" H4 sources...Even JC Whitney has them cheap (although watch their shipping charges).
http://www.jcwhitney.com/webapp/wcs/...-1&PID=1333761
eBay cheap:
http://cgi.ebay.com/ws/eBayISAPI.dll...1&category=418
Get your own bulbs:
http://www.commandocaralarms.com/ite...?ProductID=230
BTW, don't bother with the blue-tinted bulbs that say they are super white. Just get regular 100/80 halogen H4 (9003) "off-road" bulbs. You won't find them at Kragens as they are not street legal. My local autoparts store haad them for $8 each, Hella brand.
eBay cheap:
Get your own bulbs:
All: I have the same deer problem in NE Pennsylvania. But I also have a problem with being blinded by other drivers, which can make the deer problem worse should one show up w/i 10 seconds after the blue lights pass. I don't know which is worse. Perhaps this is deserves poll. It's like yelling "fire" in a theater, I want limits, those of us in low slung 928s are especially at risk to deer and lights. But frankly, there are more suvs and trucks, etc than deer.
