928 Forum 1978-1995
Sponsored by: 928 Specialists
Radiator side tank seals.
Old 10-10-2017, 10:13 PM
Mrspencer
Mrspencer's Avatar
Default Radiator side tank seals.
Does anyone know where to purchase new side tank seals, my 85 5spd is weeping. Thanks in advance,
Old 10-10-2017, 10:58 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
usually you will replace the side tank and the seal Roger sells them
Old 10-10-2017, 11:10 PM
Mrspencer
Mrspencer's Avatar
yeah, I checked his site nothing listed, guess I gotta call.
Old 10-11-2017, 01:58 AM
The Forgotten On
The Forgotten On's Avatar
To put it bluntly his site has the square route of jack sh*t on it. He can get pretty much anything you can imagine and probably has it in stock.
Call him or send him an email.
Old 10-11-2017, 11:34 AM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
There are several variations of end tanks but here’s one
http://shop.928intl.com/Raditank-No-...06%2D041%2D02/
Old 10-11-2017, 05:02 PM
davek9
davek9's Avatar
Mark is correct, and as Stan said you will want to do both, the end tank and the seal as the plastic is old and brittle and may not hold up to a re-crimp, they also almost instantly warp once removed.
There are a few ways to do the job, do a search and chose your poison.
Depending on what you are going for, I highly recommend the new all aluminum direct fit rads.
Old 10-12-2017, 10:45 AM
Tom in Austin
Tom in Austin's Avatar
I'd check with your local radiator shop ... one near me had a seal material they used on my new tanks.
Old 10-12-2017, 08:56 PM
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Don’t waste your time. The repair won’t last but a few years. Get the aftermarket aluminum one from Roger and be done with it. I tried the repair route and it lasted a few years and leaked in the same area again.
Quick Reply: Radiator side tank seals.
