MY 1990 Stalls with AC and fan on high
#31
OK, somewhat good to hear.....strangely, I was hoping to hear those numbers under load were bad
so my thinking that some compensating circuit should be keeping the voltage even with no voltage drop is off base?
i read a post regarding a 1984 and a way to calibrate the dash volt gauge, is it possible to calibrate the gauge the same way in my 1990?
#32
It is possible to calibrate the gauge, at least in my 87. It was reading about 1v low, had it all apart and had my friend connect a 12v power supply to it, and adjusted a pot on the back of gauge. It's a little wonky right at 13 but fairly accurate at 12 or 14v now.
#33
#34
I had a issue with low idle with A/C on along with a couple of other issues that I did not realize
turns out to be the jump post
looked perfect
soldered the main power wire terminal and polished the two small red wires
BIG difference everything ran better
looked perfect
#35
thanks Terry
my connections at post look great, but nonetheless, I will clean them up.
lucky for me, I have not experienced any drop in RPM with or without AC on
Fred, don't you think there should be a smoother transition when I depress the clutch? the end result is that the car recovers nicely, but only after a bit of a gulp. I just have to (want to) believe that there should be no noticeable transition
I see many posts that say the Temp II switch should be replaced like an air filter, so thinking of doing that for the heck of it.
not prepared to take out the pod and instruments just yet, so I will live with the inaccurate gauge. volt meter told me what I need to know.
#36
t
Thus what you are seeing seems voltage wise seems perfectly normal. if it is really bugging you folks like GB and Carl sell higher output alternators that will more or less make such phenomena a thing of the past. Remember our stock alternators are old tech designs and newer designs can pump out more juice for a given frame size.
