928 Forum
Sponsored by: 928 Specialists
Easiest way to remove front suspension as a unit
Old 10-04-2017, 02:56 PM
Socal_Tom
User
'84 suspension removed, including brakes since those will be part of the swap.
Total time, including chasing after the dog, some coffee and some work items to deal with on a day off, was around 90 minutes.
Both the tie rod and and ball joint took some additional time since I got the nuts loose but didn't fully remove them and then hand tighten them back on, so when I went to remove them the nuts where spinning the shafts too. Lesson learned for the other side.
Socal_Tom is offline
Old 10-04-2017, 03:03 PM
FredR
FredR's Avatar
When you want to make the joint just biff it with a rubber mallett and that will seat the taper sufficient to enable the nut to pull it in.
FredR is offline
Old 10-04-2017, 03:13 PM
FredR
FredR's Avatar
Tom
Assuming the motor is still in-situ, did you have any difficulty undoing the UCA nuts?
FredR is offline
Old 10-04-2017, 04:08 PM
Socal_Tom
User
Originally Posted by FredR View Post
Tom
Hi Fred, they actually came off without much fuss. Bonus of a Southern California car I suppose, we'll see how the S4 treats me later today.
Old 10-04-2017, 04:10 PM
Socal_Tom
User
Got the S4 lower suspension mounted, went on quite easily. I just roughly positioned it in place, used a floor jack to off it up, got a couple of nuts threaded and then tightened and aligned as I went.
Refitting time was under 10 minutes.
Old 10-04-2017, 08:28 PM
Socal_Tom
User
Done, and got the suspension bits from the '84 mounted on the S4 so I can move her around.
Tackling the other side swap tomorrow.
Old 10-05-2017, 05:37 AM
FredR
FredR's Avatar
For heavens sake get the S4 calipers painted red!
Well done.
FredR is offline
Old 10-05-2017, 04:57 PM
Socal_Tom
User
Well done.
Ha, will put that one the list.
Holy cow - the UCA bolts on the S4 are such a pain to reach.
Old 10-06-2017, 05:35 PM
85euro928
85euro928's Avatar
Personal taste but on a red car the S4 calipers look better black.
85euro928 is offline
Old 10-06-2017, 06:51 PM
FredR
FredR's Avatar
There's no accounting for personal taste!
Looked superb in red when I had my Guard's red S4. On std setup wheels it makes little difference as you cannot really see the calipers but when you have 3 piece 18 inch forged wheels and you can see everything there is no substitute for red calipers. On my Cobalt Blue GTS they are even better [of course].
FredR is offline
Old 10-06-2017, 08:16 PM
Socal_Tom
User
It will be a fine day indeed when I can prioritize thinking about the color of my calipers.
Grin.
Quick Reply: Easiest way to remove front suspension as a unit
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
