Replacements and the part name
2 Attachment(s)
While repairing vacuum lines today I noticed this one way valve was broken off. It hooks directly into the 4 way (3 way) someone has put a screw in one of the holes. It runs directly into the brake booster. I do not know the part number. I would like to replace it and replace the 4 way rubber cracked splitter with a new 3 way. I can find them I know locally but not sure if the local ones will fit such small plastic hoses that appear to go to HVAC. Any info would be great appreciated. 1983 928s
The Porsche part number is 928 537 361 02. The VDO number is 248051004001D. The valve is very common to many german cars, including VW, BMW, Mercedes and Audi. Any local bone yard will have a bunch for next to nothing. They do go bad.
The 4 way splitter is absurdly expensive and you need to find that piece used. hope this helps. |
call Roger@928srus.com he has all of those parts
4 way splitter. ??
Originally Posted by Nashvillecat
(Post 14512189)
The 4 way vacuum splitter is cheap at $5.
The blue black vacuum valve is $15.:bigbye: On your car one line is plugged so you are good to go. |
From memory: That "splitter" [usually] connects to the cruise control and the vacuum "reservoir" in the left fenderwell, plus the plastic line to the HVAC actuator solenoids at the front of the console. Source of vacuum is the check-valve you are replacing.
Got a screw in one of my ports too....
You're good. Get the other bits from Roger. |
