Bright lights stoped working
I assume you mean 'high beams'? The pins are clean for the connector from the turn indicator/high beam stalk?
This may have nothing to do with your issue but to repair the odometer you must have disconnected and reconnected the pod switches as part of the process. Check that the wire terminals have not pushed out of the socket for the headlight switch.
