Cant find: Is there a fore-aft headlight adj?
me drivers side headlight cover just touches the fender at its top, adjustment?
Edit: And one is..too high, i see some threads on ajusting that on the bar..but theyre sort of vague on how.
Follow the head light bar to where it passes through the fender wall.
On each side of the car there will be 2 bolts, 4 total. They are held in place by a bracket with captive nuts inside of the fender.
Loosen them with a 10mm socket on an extension and you can raise, lower, and generally move the head light assemblies around until you get the adjustment correct.
You can also move the headlight motor around to get it to raise the headlights to the correct degree so the cutoff is where it should be and not blind other drivers.
