Measurement needed off early power steering pump cover
This is a long shot but I am working on a self leveling suspension on a 95 Mercedes wagon with a tandem ZF pump. The OE rebuild kit is no longer available and the Febi kit seals are lacking. The Febi kit has simple O-rings where a square type seal is needed.
The outer housing seal for the 78-85 zf pump looks similar so I am hoping the housing OD matches the ID of the 33 bar positive displacement puck of the front of the Benz pump. The rear is just the normal ZF vane type.
If anyone can measure the bore at the snap ring, I would be indebted.
