928 Forum 1978-1995
Sponsored by: 928 Specialists
928 Pro Tour LS3 / Z06 Build
Old 09-22-2017, 11:57 PM
Blagave
Blagave's Avatar
Replaced steering shaft rubber donut. Replacement had different insert bushings so had to use stock bushings in new rubber.
Old 09-23-2017, 12:02 AM
docmirror
Shameful Thread Killer
docmirror's Avatar
Jeez, got to admire a guy who dives in the deep end.
What's the plan for the old Euro engine? Not to be ghoulish...
Old 09-23-2017, 12:07 AM
Blagave
Blagave's Avatar
Decided to delete sun roof, cut out sun roof sheet metal and member UNEEKONE was kind enough to sell me a roof panel and non sunf roof headliner. I spoke with painter / body man to figure out how to weld the filler piece in. I ended up recessing the edges approx 1/16th " so he would have some flexibility making everything blend.
Old 09-23-2017, 12:11 AM
Blagave
Blagave's Avatar
Was going to tig weld, but it wasn't practical, so used mig welder. Lots of tack welds. I will grind and blend the best I can and then leave the rest for the painter to deal with
Old 09-23-2017, 12:17 AM
Blagave
Blagave's Avatar
I am not one that prolongs things nor has a clear direction.
The motor that came out of the 83 conversion build is not the Euro engine.
I will be selling off the the motor, trans and torque tube down the road.
I will be taking all the smog equipment off the motor to use on my Euro car.
Old 09-23-2017, 12:20 AM
77tony
77tony's Avatar
Really like where this is going and think you missed Dinsdale Pirhana in OP credits. ..subscribed T
Old 09-23-2017, 12:22 AM
Blagave
Blagave's Avatar
Received some of the parts from Renegade for LS swap. Installed the fly wheel, pilot bearing, clutch, pressure plate and bell housing. Hoping to get motor mocked up this weekend.
Old 09-23-2017, 12:37 AM
Blagave
Blagave's Avatar
Originally Posted by 77tony
Really like where this is going...subscribed T
Now the pressure is on.
I Have read your thread numerous times and just love the detail that went into your build. People can appreciate the quality of your build, but until they have actually invested the time, sweat, research and money into a build of your stature, it is very hard to comprehend.
My goal is to come up just short of your build
Old 09-23-2017, 12:41 AM
Blagave
Blagave's Avatar
I realized that and added right before you mentioned it....my apologies to Dinsdale, the Guru of 928 mods......absolutely love the Toyota 12
Old 09-23-2017, 12:54 AM
Blagave
Blagave's Avatar
The only rust I have found on the car was in the battery box. I cut the bottom pan out and fab a new stronger one.
Old 09-23-2017, 01:00 AM
Blagave
Blagave's Avatar
Built front frame stiffener and solid steering mounts. Will make some derlon washers to match over all stock length of steering rack bushings
Old 09-23-2017, 01:02 AM
Blagave
Blagave's Avatar
Sourced Aero mirrors and purchase base from Roger.
Old 09-23-2017, 06:40 AM
Tamaren
Tamaren's Avatar
I'll always follow a clean build like this. The LS is a great motor- shame CA choked it down on you, but shouldn't matter that much. Beautiful!
Old 09-23-2017, 01:10 PM
Michael Benno
Michael Benno's Avatar
Originally Posted by Blagave
Built front frame stiffener an solid steering mounts.
Any chance you would be interested I building second frame stiffener? I would be interested.
Old 09-23-2017, 09:08 PM
Majestic Moose
Majestic Moose's Avatar
Are the suspension parts media blasted or painted? They look great.
Quick Reply: 928 Pro Tour LS3 / Z06 Build
