Alternate rebuilt steering rack
Has anybody tried this? I was shopping for one and was planning on pulling the trigger on the one from 928 MS but stumbled across this. I'm always a little leary of not tried-and-true parts, more so when it comes to steering, but the $200.00 difference is interesting. If it starts to leak, it has a lifetime warranty, so I can just return it.
If nobody has put one on, then I will stick to the original plan.
http://www.autozone.com/suspension-s...45_838244_6207
Most companies don't machine the shaft inside of the rack which can corrode and cause the new seals to fail. That most likely includes autozone.
The one's from 928 International are machined and have a very high reliability rate. I don't know about the one from 928 MS though so I'll remain neutral on that one.
Go with the ones Roger or Mark have rebuilt. Zero issues will be had.
Chronic Tool Dropper
Amen! The amount of available fun with changing the rack, along with the tie rods and ends plus the wheel alignment, makes getting a proven unit a worthwhile investment.
I painstakingly rebuilt a rack on my own and then patted myself on the back for being the smartest guy in the room by only spending coin for the rebuild kit.
A week later, it failed.
Then I bought a rebuilt rack from Roger and have not had an issue since.
As was pointed out above, for me it wouldn't matter a lot if the autozone product is guaranteed, the act of having to pull the rack off each time is just too much time up in smoke...just my two cents.
So much mirth.
I recently got a 928 alternator at AutoZone. It's an incorrect Audi unit (I think) with no attachment for the shroud and just 75A. Ordered it at the neighborhood store and picked it up 2 days later for $75, total. Handed them off the same type unit that I had purchased off-the-shelf 12 years earlier from another FLAPS.
The failed unit would have been fine for another 12 years except I drained some PS (ATF) fluid right into it. Not across it but into it as it was laying under the car. Let off some unpleasant smoke after re-install and it was dead. New brushes didn't bring it back. Those are dead simple on a Bosch unit.
Actually what you did was a reseal .....and what is being sold as kits are RESEAL kits often using generic seals which appear to fit...
Received 1,542 Likes
this --^
The actual rebuild kit from ZF is >$700.
