928 Forum 1978-1995
Sponsored by: 928 Specialists
ABS Harness Refurbishment experimenting
Old 10-30-2017, 11:08 AM
bureau13
bureau13's Avatar
I need to repair my right front harness as well. If you recall the bracket that holds the white connector snapped off, and the wires got pinched in the suspension and broke right at that connector. Roger was able to find me the proper bracket (I apparently have a Frankencar w/ the old bracket) and I have a used harness, but the part inside the engine bay is not very good. Can I cut off the broken wires on the harness in my car and splice with the good half from the used harness? Is there reason this wouldn't work?
Old 10-30-2017, 04:35 PM
Michael Benno
Michael Benno's Avatar
You could remedy this a couple different ways.
1. Purchase new harness. This would be the most expensive way since they can be unto $250 each, and the new ones are very hard to find. I believe 928srus sells them
2. Buy a replacement used harness. I see several on eBay right now. Find one with a good looking connector.
3. Buy a harness for parts (e.g. good connector) and splice the wires as you suggest.
FYI 944's, 968, and 911's of this vintage used the same ABS harness connector. You can use them as part sources or replacement harness so long as they are about the same length or longer than the one you need. If you go this path, note that the rubber grommets won't line up; you will need replacements.
Old 10-30-2017, 08:40 PM
fraggle
fraggle's Avatar
I rebuilt my rear harnesses back in 2010. https://rennlist.com/forums/928-foru...ild-87-s4.html
Old 11-01-2017, 06:04 PM
bureau13
bureau13's Avatar
A while back I went with Door #2, but the engine bay connector is in worse shape than my existing harness....which is why I was wondering about Door #3.
Looks like fraggle has been through this door...very nice. Door #3 it is!
Old 11-01-2017, 07:57 PM
fraggle
fraggle's Avatar
I'm going to do the fronts with new weatherproof connectors in the engine bay. The originals turned to dust and I'd rather just go with a modern 4 pin of some sort.
Old 11-01-2017, 09:44 PM
Captain_Slow
Captain_Slow's Avatar
Hmmm...this would be great tech session for Frenzy next year. Or, a fun rebuild party. Everyone pulls one harness to rebuild and goes home ready to do the other three.
Old 11-02-2017, 12:09 AM
XS29L9B
XS29L9B's Avatar
+1
Old 11-02-2017, 01:10 PM
Harvey928
Harvey928's Avatar
Old 11-02-2017, 01:41 PM
Michael Benno
Default Frenzy fun
If someone does take this on as a tech session at the frenzy, I would be willing to lend my two harness for experimenting. So long as I get them back in one piece and functional.
I have two harnesses that have been stripped of rubber coating. One I have started dipping and the other is still un treated.
I live in Portland and won't be attending, but I can mail them down.
Old 11-12-2017, 11:23 PM
Christopher Zach
Christopher Zach's Avatar
Update: ABS light came on this week, so I put the car on ramps and looked at the wires.
This time the passenger side harness wires had drooped right over the wheel end of the axle on those CV joints and were wearing away. AARRGGH! So it was time to install all of the grommets on the rear wires.
Grommets go in one way only, split them with an XActo knife, put liquid electrical tape on the wire (it was just the insulation rubbed, no wire damage) then start putting them in. Two around the CV joint, then one going up, then two on the car, then another one on the car, then do the other side. Burned through a lot of them, but the harness is now very properly supported and should never go out again.
Which is good, I like ABS. But man, zip ties won't work, you need to get these groovy grommets!
Old 11-13-2017, 12:04 AM
Michael Benno
Default Grommets
which grommets did you use? Got pics
Old 11-13-2017, 12:31 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Roger's got reproduction ABS harness grommets, $28 a pop.
https://rennlist.com/forumshttps://r...es-mounts.html
Old 02-07-2023, 03:01 PM
Rob Edwards
Archive Gatekeeper
Kroon is now producing the left rear harness for '84-89 (928 612 405 00), with more variants to come.
The following 3 users liked this post by Rob Edwards:
gerakroo (02-17-2023), Kevin in Atlanta (02-07-2023), Speedtoys (02-07-2023)
Old 03-10-2023, 01:36 PM
Michael Benno
Default New idea on DYI repair
A few years later from the original post, I thought I would give an update on a different approach to a DYI repair of the crumbling rubber coating and grommets. A quick disclaimer. All the harnesses are still available new ranging in price from $100-$220 depending on the part. So you should definitively replace your old harness with a new one.
But if you want to repair your harness, check take a look below. I stripped off all the old rubber and grommets and re-sleeved the harness with oil/fire-resistant woven split wrap (3/16"). And then used some sections 1/4" fuel hose and
 harness holder harness holder
s to mount into the OEM position in the hub and chassis. I have yet to secure it to the chassis yet, but I have test fit the harness clips into the exiting mounting holes.
The following 4 users liked this post by Michael Benno:
Babado (Yesterday), Bertrand Daoust (03-11-2023), drkekar (03-10-2023), Mrmerlin (03-11-2023)
Quick Reply: ABS Harness Refurbishment experimenting
