New Tow Hook from KLA Industries
KLA Industries is introducing a new tow hook and mount for car not having either front or rear tow capability. The tow hook mount is designed to mount behind the bumper (front or rear) and bolts to the bumper. When you need to tow or tie down you car, you screw the steel hook into the receiver and your ready to go.
To mount the assembly requires drilling three holes in the bumper. Two holes are for the mounting screws (supplied with the mount) and one is for the tow hook. Never tow a car again my wrapping a chain to the expensive suspension on your car.
Well the tow eye mount will mount to the inside of the bumper like the factory. Wen you use the eye it will pull against the mount point. You might look and see what structure you have at the area where you want to mount it to determine if you have a solid mount point otherwise I would not suggest mounting it to a plastic or glass bumper.
