Removing antenna wire from radio plug
How do you get to the antenna wire connection that plugs into the stereo from under the dash on my 924S ? I removed much of the panel area inside the car, looked under dash - followed wire, but cannot seem to easily get to the wire that plugs into the stereo. I have a removable radio, so that may compound the dyi.
I would think it should not be difficult so obviously making it more difficult.
Checked Clark's garage and did search with little help.
BTW, I do know how to remove antenna from fender.
TIA.
TIA.
I usually just plugs right into the back of the radio so if you remove the radio its just a matter of unpluging it, that is if i am thinking about the same thing you are.
