Gas tank isn't venting
Yesterday I noticed that when I turned off my car, I heard a liquid gurgle coming from back near the filler neck of the gas tank... I got out and went to check the gas cap - only to find that when I took it off, air pressure came out of the tank.
Anyone else have that happen? I'm assuming the vent line is some how clogged up.
I'll let you know what I find.
It happens to my track car all the time i.e. the tank develops a positive pressure. This used to be counterintuitive to me, as I thought the tank pressure would reduce as gas was consumed. But I've since decided that the gas bypassed at the fuel pressure regulator under hard hot driving conditions is heated up, returned to the tank, and the total volume of the gas is increased due to it being heated.
My track car has the line that would normally go to the charcoal canister vented locally at the rear of the car. There are multiple chances for failure in the stock setup. I don't profess to understand how the system at the front of the car works but for instance if the heat activated vacuum valve at the rear engine heater hose connection stops working, I'm not sure the system would ever activate. Various check valves at the rear of the car. And on and on. It seems like a lot of hardware and complexity compared to a gas cap with a hole in it!
Yeah, on my track car I have the vent line open to atmosphere are the back of the car.
This car, however, is my street car, which has all of the factory emissions stuff in place.
Here it is, 4th of July parade ready!
Having a filter on the open line under the hood sounds like a recipe for disaster....don't most people feed the line to the dirty side of the air box?
Cars look great Van!
On my track car I fitted a tip valve on the tank and removed all the vent lines. The tip valve allows the tank to vent to atmosphere when it is not on its roof
My 87 Scirroco used to build up so much pressure it would make people jump back when opened. My 84 944 builds up pressure too (rare un-cracked tank , if the S2 does it's only slight.
Van - check the vent line that comes out of the tank. It might be pinched between the tank and the frame. I have this issue with my race car from time to time. If the tank starts to expand it pinches the line which make it worse. There is zero clearance between the tank and the frame but somehow my vent line found it's way between there. Might be worth looking into.
SC
SC
I believe the rear 'vent' is an inlet as fuel is consumed.
you might give the charcoal canister a shake to see if the pellets have been set free, thus clogging up the plumbing.
shake any jug of fuel and it will build vapor pressure. shaking up your fuel tank should push the excess pressure towards the charcoal and, of course, after you are warmed up, the engine vacuum 'purges' the vapor from the charcoal.
generally speaking.
generally speaking.
Good call on the vent line from the tank to the dirty side of the airbox. Might have to run a new one to do that...pulled mine out when I pulled all the brake and fuel lines..Getting rid of the emissions stuff, canister etc.. still like the idea of a hole in the gas cap though..
I've taken apart the little 3-way fitting from the vent line to the charcoal canister to the recirc valve / intake manifold... and, after removing the fuel cap, used compressed air to blow into the vent line and the charcoal canister. The vent line seemed clogged and took some pressure to clear... the charcoal canister had some water in it that blew out.
So far, it seems to have solved my gurgle noise.
