The Transaxle Era
Old 03-31-2017, 05:27 PM
MAGK944
MAGK944's Avatar
Default The Transaxle Era [Video Content]
Cool video, apologies if its a repost.
Old 03-31-2017, 08:00 PM
marc abrams
marc abrams's Avatar
Nice video, thanks for posting.
Old 04-03-2017, 01:32 PM
neunfünfeins
neunfünfeins's Avatar
Sure I know "why", but it's still a curiosity/oddity to me that these cars are being distinguished as 'Transaxles'. Alone, the term is too broad and ambiguous.
By definition, the 911/912/914 and practically every other Porsche sports car are also "transaxles". As is every aircooled (RWD) or watercooled (FWD) Volkswagen, and your typical oldschool riding lawnmowers.
I guess 'Front-Engine / Rear-Drive Transaxle' doesn't roll off the tongue as readily though.
Old 04-03-2017, 06:42 PM
marc abrams
Yes, I thought the same thing too. Someone here on RL explained to me "Transaxle" in German means "Drive Shaft".
Old 04-03-2017, 07:17 PM
MAGK944
MAGK944's Avatar
There's some reference to the origin of term "transaxle" in this article on porsche.com
Old 04-04-2017, 12:04 AM
neunfünfeins
Hmm... the plot thickens.
'Driveshaft' in German is 'Antriebswelle', and 'Propshaft' is 'Kardanwelle'
According to the nifty 'The Transaxle Era' book I got from the Porsche Museum, 'Transaxle' is.. well, 'Transaxle'.
Or more explicitly:
'Front-motoren und Transaxle-Getreibe an der Hinterachse'
Literally: "Front engines and transaxle-gearboxes at the Rear axle'
Thanks, I had run across that article before and assumed that the author was either (a) a contributor to these "alternative facts", or (b) a victim of them.
A transaxle is any gearbox that combines the transmission and differential into the same unit, hence the discrepancy.
By all indications, it's being... shall we say... "repurposed" in this context to put special emphasis on the "trans"-mission of power from the front to rear of the car via a driveshaft. Whereas in other examples I gave, engines and transaxles are typically mated directly.
Seems to be more accurate they should have just called them the "Torque-tube cars".
I can accept it. Still funny though.
Old 04-04-2017, 03:09 AM
MAGK944
MAGK944's Avatar
Originally Posted by neunfünfeins
...Thanks, I had run across that article before and assumed that the author was either (a) a contributor to these "alternative facts", or (b) a victim of them. ...
The writers at Christophorus spreading alternative truths.....
..........nooooooooooooooo
It seems the term was probably something that somebody attached to the front engined, rear trans cars and it just stuck and now even the factory uses the term. I doubt there is any reference to a transaxle when these cars were in production. I bought one of mine new in 1986 and don't recal hearing the term used by the dealer at the time.
Old 04-04-2017, 04:46 AM
Voith
Voith's Avatar
They did use the term in original marketing in 1977 and specifically called torque tube - Transaxle.
This ad translates to: gearbox at the back, engine at the front, transaxle in the middle.
This Transaxle video is nice, too bad it's in German..
Old 04-04-2017, 08:16 AM
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Ha. That's good.
I posted an article from Hemmings which also covered the 40 year anniversary of the "transaxle era". It got similar responses as here.
If I find it again, I'll insert the link....
Found it. It's been nearly a year:
https://rennlist.com/forums/924-931-...ransaxles.html
Old 04-07-2017, 07:24 PM
gtroth
gtroth's Avatar
https://en.m.wikipedia.org/wiki/Transaxle
Old 04-08-2017, 07:00 AM
J1NX3D
J1NX3D's Avatar
I guess 'watercooled era' would have too confusing once the boxster and 996 were introduced.
Old 04-20-2017, 02:38 AM
neunfünfeins
I'd call that theory Plausible.
That's a good find!
Note that they didn't simply call it a 'Transaxle' though, it was qualified with location/position of engine as well.
This might support the theory that in usage, over the years, it simply got shortened to 'Transaxle' because nobody wanted to have to say the entire mouthful.
Concerning the 'Transaxle Era', I'm still tempted to level accusations of 'Revisionist History', however.
Good point.
Old 04-20-2017, 03:39 AM
951Dreams
951Dreams's Avatar
I bought a 87 944 brochure, it also mentioned these cars as "transaxle" I'll get the exact quote when I'm not feeling so lazy.
Old 04-20-2017, 11:56 PM
Tiger03447
Tiger03447's Avatar
Brochure states: Gearbox rear..Motor in front, Transaxle in between..more driving safety ..active and passive.,.
Old 04-21-2017, 01:01 AM
neunfünfeins
The word 'transaxle' also appears in some period 911/912/914 literature, but that doesn't make those cars any more or less worthy of being called 'Transaxles' than these, either.
Again.. the distinction I was making is when the 924/928/944/968 are referred to as 'Transaxles' in the absence of any other contextual description about the drivetrain.
If there is an example of period literature that does so, then we should consider that a finding.
The word 'transaxle' simply appearing in the literature - in the same context as all the other words like "front motor", "rear gearbox", etc. - has already been posted here, and is kind of missing the point of the discussion. Which is, how did this whole notion of these cars being singled out as 'Transaxles' - and no others - get started in the first place.
That's why it's a curiosity (to me, at least).
Quick Reply: The Transaxle Era
