My recent rough idle saga-vacuum leak
I started noticing a bit of rough running, poor idle, poor throttle response, etc. I suspected so many other things that I thought I would post the final fix.
It was a vacuum leak, bad intake gasket, but I suspected these things:
-Bad muffler, it was popping and farting a lot.
-Bad throttle switch, it was much worse than normal on transition on and off of closed throttle.
-Fuel pressure problem
-Ignition problem
Most of the searching I did mentioned vacuum leaks, I was able to hear mine it was so bad, but check carefully when you have problems!
-Ignition problem
