Bought a 944, should I fix it or part it out
Old 06-04-2016, 08:47 PM
Jimmyac28
Jimmyac28's Avatar
Default Bought a 944, should I fix it or part it out
I started a thread before when I was looking at this 944 a 924 and a 928, that thread got out of hand because it turned into a purist vs V8 swap guys.
Here is my issue, after I brought the car home and cleaned it up a little aside from the paint and a little dent in the back the body is in decent shape. The interior is decent with some broken plastics here and there, cracked dash, factory steering wheel was swapped for a GT grant steering whell and almost mint looking sport seats and rear seats. The car also has some very desireble options like fuchs 15" wheels, and the m456 sport suspension with front and rear swaybars. Mechanichal wise transmission shifts smooth and engine runs strong but its in need of a new water pump, so it will need water pump and timing belt replaced along with seals and rollers since I have to get in there anyway.
Here is where my issues start and I dont know if it will be worth it restoring this car:
The car is currently painted black, the original color was saphire metallic. I really like tge black so I wwas just thinking about repainting it black until I kept inspecting under the hood and found some scratches that you can see red paint, I think most of the front end came from a red car suggesting the car was in a front end collission sometime in its lifetime but the tittle is clear and not salvaged. None of this would raise too much concern since its a old car and its expected to be in it fare share of fender benders and such. Now for my biggest concern, I noticed some silicone or something similar on both strut towers so I peeled it bach some on the passenger side and under it I found some kind of copper welding and that is whay I not sure if the car would safe to fix or should I just forget about it part ot out and try to find a better one. I attached some pictures of the car and the problem areas Im talking about. Also the vin number under the hood and the one on the windshield all the numbers are the same and in the same order but some of the letters are different, is this normal?
Old 06-04-2016, 09:28 PM
grenadiers
grenadiers's Avatar
Looks more like brazing type of 'weld'. What's it look under the fender, under that spot? Overall, you were looking for a project, right?
Old 06-04-2016, 09:48 PM
Jimmyac28
Jimmyac28's Avatar
I have not looked under that spot yet, I will look tomorrow. And yes I wanted a project and I really dont care about all the other issues as those can be fixed but if this weld turns out to be some king of strutural issue I dont think the car would be safe specially if I carry out my plans and do an engine swap
mytrplseven
mytrplseven's Avatar
Part it out. It's just not worth the aggravation.
Old 06-04-2016, 10:44 PM
Tiger03447
Tiger03447's Avatar
Does it run? Apparently so..you got it home..So how did it run? Apparently this is an early car from looking at the heater inlet and the strut mounts. Keep it and drive it ...I wouldn't recommend a v-8 swap...if you want a car that you can drive and enjoy, this might be worth it..If you want a hot rod car, get a Cobra kit and put the v-8 in it. Factory Five racing has some nice ones. That way you can get 8 cylinder rated brakes, transmissions, and rear ends that you won't have to juke with all the time. But it appears that you have a nice driver for about 500.00 more dollars invested, or less, perhaps. Enjoy it, and use it for a grocery getter..Buff up the paint a little and keep the investment low...if it has a serious break, then part it out. My .02 cents...
Old 06-05-2016, 12:03 AM
jhowell371
jhowell371's Avatar
Old body repair done by brazing. I wouldn't worry about it. Body shop friend of mine in 1981 made one 924 out of two totals, one wrecked in the front, one in the back. Clipped them at the windshield posts and the rear of of the doors. I drove it and it seemed fine. I ran across it a couple of years ago in a boneyard, it never broke in half
Old 06-05-2016, 02:20 AM
KVDR
KVDR's Avatar
Not sure what you paid, or your budget, or your current plans.... but if this runs and will pass a safety inspection with minimal cost/repairs, then you should just drive it and enjoy it. Don't put any real money into it.
Probably a good car to learn how to fix the 944.
Old 06-05-2016, 02:23 AM
Jimmyac28
Jimmyac28's Avatar
Do you think it was in a front end collision and they used the front of another 924 and welded it to the rest of the car?
Old 06-05-2016, 02:26 AM
Jimmyac28
Jimmyac28's Avatar
Yes it runs good, just needs the water pump and a good tuneup. It even passed california smog inspectio before the water pump went out on the previous owner and he parked it for almost a year before I bought it. I might just fix it up and use it as a gricery getter maybe get a good paintjob later on
Old 06-05-2016, 02:29 AM
Jimmyac28
Jimmyac28's Avatar
Well I only paid $600 for it and just the wheels are worth almost twice that. Thats why I got it because I can fix the water pump and drive it. If it dies on me I can always sell the wheels and get my money back
Old 06-05-2016, 03:08 AM
lart951
Basic Sponsor
lart951's Avatar
How much for the seats?
Old 06-05-2016, 05:38 AM
Alaska Cabrio
Alaska Cabrio's Avatar
Have you tried doing a VIN search on the numbers? That might tell you what is going on with the different numbers.
Mike
Old 06-05-2016, 08:06 AM
grenadiers
grenadiers's Avatar
The number on the firewall is the Porsche Chassis Production Number. The number on the windshield is the Market Chassis Serial Number.
Old 06-05-2016, 10:22 AM
curtisr
curtisr's Avatar
I hope I didn't miss this but have you run a Carfax or similar history-finding service on the car? That should answer any question about its past.
Old 06-05-2016, 10:48 AM
mel_t_vin
mel_t_vin's Avatar
Normal...yes, all US chassis VINs have the 4th, 5th, 6th, and 9th digits replaced with a "Z".
Quick Reply: Bought a 944, should I fix it or part it out
