Eric's 1987 944S Rebuild Project
Fair enough. ~$90 for straight up replacement of both items. Make that 5.09k investment
Quick update. She lives. Had a devil of a time figuring out oil pressure (there was none). With no fuel or spark plugs installed, just turning over, there was no pressure. Two weekends later, here's how we fixed it.
1. Remove oil filter.
2. Add appropriate amount of oil to crank case. Keep in mind, if doing a ground up build, you need a little more to eventually fill the oil filter, plus you'll lose some with this process.
3. Take your air compressor and using a spray nozzle, remove the dipstick and crank the compressor up to around 80-100psi.
4. Crank over the car (less spark plugs and oil filter).
5. Oil should finally be forced up into the galleys and start pumping out of the oil filter main line.
6. Reinstall filter, continue cranking without spark/fuel until oil pressure rises and filter fills.
7. Button up everything.
Also had a electrical snapping noise that I thought was a lifter at first. Turns out it was a compromised spark plug cable arcing to the cam tower. I only figured this out when I happened to catch it in a video I took of my dad backing the car out of the garage for the first time. Replaced those with some cables from Paragon. That's fixed now as well.
Headlights are re-assembled and back in. Basically the car is just a couple weekends from being road worthy. Last major thing is to repaint the rocker panel between the lights and the hood because of rock chips and the giant burn spot. By the way, aligning headlights with various body panels is a serious pain in the butt.
The major thing to fix this weekend is electrical gremlins. Once that's finished, I can finish the last of the interior reinstall. Basically got seats left to do and deep clean. Blinkers only work on one side (right). Got a new relay/bulbs coming from Paragon. Hopefully the weather is nice and dad can shoot the hood and rocker panel.
Should have a proper video up this weekend sometime.
