oil pressure sender - what ruins them
currently futzing with an aftermarket VDO oil pressure gauge that used the blue/white wire that was going to the instrument cluster as Sender wire to the new gauge.
I had it working then no response from the original or new gauge
Fast forward... i put in a new sender, things went to normal, the original gauges worked, then the new one worked when i moved the connection to it.
I then soldered everything up and seated the new gauge in the lower console it stopped working again.
i reverted everything back to original. no joy, both new and old gauges not working.
also ran new wires all the way from new sender to gauges to eliminate 'is there a broken wire', still no joy
I admit i could have been a bit sloppy with the ground and 12volt on the new gauge, although i don't recall any shorting.
Is it possible i fried the new sender? Btw the idiot light still responds correctly...
