Power steering rack reassembly for core charge
I took apart my rack thinking I was going to rebuild it and once I got in there I realized that I had basically 0% faith that I would be able to reseal it without leaks.
i've gotten my rebuilt rack in and I'm trying to reassemble my old rack to collect my core charge.
I can't seem to get the control valve to slide back into the casing, no matter how I wiggle/slide things. Is there any trick here?
See picture.
See picture.
Take the little plate off the side where you have it clamped in the vice. Two 10mm bolts. There is a spring under it that keeps tension on the rack / pinion gear. When that is removed it should twist right in.
