Need to borrow a good DME for a 1987 944
Hi all - I am in the process of resurrecting a 1987 944 na that sat for approximately 11 years. So far I have replaced the water pump, timing belt, reference sensors and many other items, but I am getting a no start. I've tested the usual suspects including DME relay, fuel pump, etc. I really think it may be the DME itself, but before I drop $300+ on a rebuilt unit, can anyone in the north Atlanta/Gwinnett area loan me a known good one for a couple of days. There's at least a six pack in it for your trouble.
Thanks |
Bump. Anyone? I would gladly make it worth your while. As an alternative if someone could test my unit that would at least tell me if there is a problem.
1 Attachment(s)
Specialized ECU has a video on Youtube to test the reference sensors. Just a beginning but may help you.
Website: http://www.ecudoctors.com/faq.html I would also begin by cleaning EVERY ground on the car especially the battery to block. Cover the flywheel access hole on the top of the engine or you WILL drop a nut or bolt in the hole. Attachment 956339 GL J_AZ |
Thanks. The reference sensors are both new and properly tested. The battery is new and the grounds have been cleaned. Fuel pressure is good as well. Injectors are firing. I have re-soldered the usual suspects within DME. I went through something similar on my 911 a few years ago. In that case it was the DME but I was able to fix it by resoldering a few joints. This time it isn't working. I also swapped coils.
