It won't buff out. Advice needed.
So I tagged a guardrail the other night and I'm not sure how to proceed.
[IMG]http://[/IMG]
Can they just cut out the damaged part and weld in new? Or weld in a piece of a used but not damaged fender?
I took it to a body shop yesterday, and they were talking about taking the entire fender off by drilling out all the rivets,
after they remove the hatch, etc.
[IMG]http://[/IMG]
1 Post
To the OP. A decent bodyshop should be able to repair that without replacing the quarter. Cutting out that panel would be more work than its worth for that level of damage.
Goodluck!
It's going to have some filler in it before paint but truly it's not as bad as it looks, especially given that it is cosmetic and not structural damage. The friend I use would be able to make that look 100% without any panel replacement. Do your homework, it's going to take a good body shop but if you choose wisely I don't see why you don't get the car back looking perfect. You might want to check the wheel alignment and all the suspension parts.
PS Is that the zinc coat / primer exposed or has that panel been shot before?
Piece of cake for any decent body shop!
Most larger shops will replace. They make more money and spend less time.
If you go to a hole in the wall place, they will actually repair that to look like new. A mobile body shop can do that too.
Go to a shady part of town, you will find shops that do old school repairs
Thanks guys, I now think the place I went to pretty much is like what djantive said, they're mostly a bolt on/off paint shop. I'll find a more hands-on place.
terbiumactivated, I think the grey you're seeing is from the gaurd rail?
BTDT brother, I feel your pain.
Take the inner plastic panel off for access from behind. I used a small !" thick phone book or paperback snugged up against the metal, then whacked that with a dead blow mallet to bang out the major part of the dent. Get a contour gauge from Home Depot (~$5) and use it to get proper contour from the other side of the car, to see how much to bend the metal back into shape.
I've seen YT or other sources of shrinking sheet metal, but not tried it yet. This involves spot heating the metal, then suddenly quenching with icewater in a rag or sponge. Reportedly, this might help. Maybe heat from behind but not so hot as to fry the paint, then quench. If so, you may be able to reduce the damage to a point that a paintless dent removal guy can do the final touches. Or not.
