Needed: a few parts
Needed: a few parts
I have a damaged connector on one of my reference sensors. The PO got ham fisted and broke both sides of the connector (male and female) If you have a male connector from a bad or throw away reference sensor and a female side connector (that goes to the DME) I can replace the damaged ones. I'm also looking for a couple of the dimpled washers that hold the wood floor board down over the DME. The leaky battery box rusted the ones I have. I'd appreciate any of these parts if you have them. Thanks in advance for your help. Drop me a PM.
That would be greatly appreciated. I was doing a check for the recommended resistance in the reference sensors when I noticed that the bottom plug on the mount was broken. I'll look forward to hearing from you.
Sorry to get your hopes up, i must have tossed them during my last garage cleaning. Good luck in your search. I gave a couple brand new sensors to another member, ill message him and see if he still has his old ones.
Hey. Thought I replied to this. I have the female connector one the harness that goes to the DME. Do you want just the connector? Want me to cut it off? How much wire do you need? Need the whole length of the wire? I sold the speed sensor itself and don't think i have a spare connector for it...
$12 shipped for the female connector?
I have a bunch of the wiring harness left from a car I parted out, not sure if it has the connectors for the sensor on it - the car was an S so it would only have one connector anyway. PM me only if your other sources fail.
944online.com has the replacement sensors connectors. Male or Female, 944/1-2 or S / Turbo etc...
http://www.944online.com/cgi-bin/ASI...lectrical-9442
