FS: Garage Cleaning Thread
I have quite a few miscellaneous items that I would like to clear out before moving. All prices are plus shipping, though I will offer a considerable incentive for those who buy multiple items! First one to pay by PayPal gets the item or items.
DO NOT QUOTE THIS WHOLE MESSAGE IN ANY REPLIES -- it's still fairly long and it will get confusing.
H&R 65mm wheel stud kit (10 studs and rotor screws): $60 SOLD
21mm hubcentric spacers (2): $40 SOLD
Steering shaft (like new): $20
968 Steering wheel with airbag and clockspring (Click for additional photo of scratches on top of wheel): $50
Late cooling fan (like new, from Lart): $40
Under radiator rubber feet (used for one year): $5 SOLD
AC Delete alternator belt: $10
Late ('87 and later) front wheel bearing and seal kit for one wheel: $15
New door stop check: $10 SOLD
1 year old updated 968 caster blocks (replaced when I went to High Strung 44 arms): $40 SOLD
Working but ugly 968 starter: $60
1 pound of 80A hardness liquid urethane for transmission mount mod: $20
968 (and probably others) transmission output axle shaft seals (where the oil gets out around your axles -- set of 2): $10
Steering rack boot: $5 SOLD
Used aluminum lug nuts in acceptable condition (20): $10
Left and right late turbo control arms with 2-year old ball joints (rebuild done by Blaszak Precision): $150 SOLD
Stock 968 torsion bars: $40
Lightly used (70% remaining) Hawk HPS pads for M030/928S4 black front calipers: $50
Complete set of good Pagid black street pads for non-M030 Turbo/S2/968 (8 pads = 4 wheels): $70 SOLD
Complete set of cheap (Textar?) street pads for non-M030 Turbo/S2/968 (8 pads = 4 wheels): $20
Front brake scoops and backing plates: $20
New rear only braided brake lines: $20 SOLD
Spring plates (useable as-is with decent rubber) and Weltmeister bushings to replace that rubber: $100
Lindsey Racing 2.25" spring hats for using coilover suspensions with standard strut mounts: $60 SOLD
Four late strut mounts with good bearings (some compression on all of them, to varying degrees): $50 for all four SOLD
Alternator with new voltage regulator, no pulley and noisy bearing, plus both required new bearings (in boxes): $40
AC compressor and alternator mount: $30
AC delete alternator snorkel: $20 SOLD
AFM from an '88 Turbo: $50 SOLD
968 (16v?) intake gasket: $10 SOLD
Exhaust flange gaskets (2): $10
968 valve cover seal kit plus extra outer seal: $20 SOLD
Switches, relays and good DME temp sensor (fan relay will power fans, but could use repair): $20 SOLD
New Bosch 968 fuel pump, tank strainer and fuel filter: $100 SOLD
I think this is a 951 fuel filter (check to be sure, though!): $10
Yellow Lamin-X covers for S2/Turbo fog lights: $10 SOLD
Stainless steel instrument rings: $20 SOLD
Turbo distributor cap: $15
968 distributor cap and wires: $75
1 CV joint kit (check part number to be sure it works for you): $70
1 CV boot kit with grease: $15
Inner window scrapers: $15
Upper and lower balance shaft seals: $10 for both
16V valve seals (16): $10 SOLD
4x Brembo bleed screw caps (new): $10 SOLD
Very nice black Lloyd's matts, not losing foam: $100 SOLD
968 grille: $30
1 used front non-M030 S2/Turbo/968 brake rotor (Zimmerman x-drilled e-coated): $40
968 fuel rail cover powder coated silver: $50
968 grille: $30
