clanking noise from rear left wheel
The rear end of the car does not need to be raised, but, it sure helps.
Check these bolts. I had similar issue and it ended up being loose/missing bolts on axle to diff. Glad I caught it before it completely disconnected. I have a pic of culprit in my recent thread.
Changed my CV axel a few weeks ago and got myself a good set of triple squares. Be careful to clean the bolts as advised on this forum. I broke three and had to get a shop to finish my mess. Lesson learned.
No worries, Russell.
But listen to Carlos, and others, and make sure you've got a solid, high quality, triple-square socket before you undertake this endeavor. Many an axle bolt have been rounded/destroyed due to lesser-quality tools.
Happy motoring...
Happy motoring...
I appreciate the heads up and sorry if I don't know all the nomenclature used, most my tools are SAE and most cars I have worked on are American hot rods and classics, so all of this including the tight quarters is going to take some getting use to.
Have a great 3 day weekend!
Not certain what a tripple square socket is, I did go get from automotive store a 8mm 12 point head drive and a 6mm allen head drive, I got underneath and sprayed the heads, etc. with WD-40 and will make sure I clean out the recesses as best as I can before loosening.
BTW, a triple square = 12-point cheesehead, so, you've got the right tools for the job.
Thanks again everyone!
Sometimes, noises that sound like they're coming from the rear are really coming from the front. Wouldn't that be nice...
Before you decide to press out the bearings in your rear trailing arms [not the easiest of jobs], verify that your front wheel bearings are properly adjusted.
