chain pad tensioner, which to get, zims vs. vertexauto
Old 03-19-2013, 10:03 AM
veleno
veleno's Avatar
Default chain pad tensioner, which to get, zims vs. vertexauto
So I'm about to order the replacement pads but wanted to find out which is the better one to get between the one at Zims ($118.95) or the Vertexauto ($109)?
Old 03-19-2013, 10:31 AM
carlege
carlege's Avatar
With shipping or without? you might be surprised what the actual total would be.
Old 03-19-2013, 04:42 PM
Der Treiber
Der Treiber's Avatar
I used the Zims pads, and they fit perfectly-nice and snug.
Watch those tiny washers on the j-tube like a hawk...they'll get away from you in in an instant. Also, plug the oil galleys on under the center of the exhaust cams...they have an appetite for tiny washers....or so someone told me. :ducking:
Old 03-19-2013, 04:51 PM
Arominus
Arominus's Avatar
Make sure your j-tube is still there... Mine was blown away by age (stupid plastic tube), only the ends remained. Had to get the new metal j-tube to replace it.
Old 03-19-2013, 04:56 PM
Jason @ Paragon Products
Jason @ Paragon Products's Avatar
They're small and light. Perfect fit for the USPS Small Flat Rate Box
http://www.paragon-products.com/Cams...9.kit-rail.htm
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 03-19-2013, 07:28 PM
veleno
veleno's Avatar
Sounds good!
Old 03-19-2013, 11:34 PM
Jay W
Jay W's Avatar
I almost lost those J Tube washers down the oil galley because I assumed they were steel. I had my magnetic pick up tool below the bolt to catch the washer as it came out. Found out the hard way the washers are actually aluminum.
Old 03-20-2013, 09:00 AM
polskimonster
polskimonster's Avatar
I've purchase my pads from the Porsche dealer just last week. With the PCA discount I paid under $100 including tax. I've purchased few other items from the dealer, like engine mounts and I paid $176 per mount, I feel they've been good to me.
Old 03-20-2013, 10:19 AM
veleno
veleno's Avatar
Really? I didn't think the dealer sells just the pads, guess I was wrong.
Do you have a part number handy that I can reference?
Thanks.
Old 03-20-2013, 03:28 PM
KevinGross
KevinGross's Avatar
Replacing the J-tube (which is all metal, unless there's a new design) is a good idea: time will fatigue the connection between its banjo ends and the pipe. I have not seen this fail on an 944S/2, but have seen many failures on 911 Carrera chain tensioners.
Kevin
Catellus Engineering
Old 03-20-2013, 05:09 PM
Arominus
Arominus's Avatar
Kevin
The original design on the "S" was a plastic tube, which was then superceeded by an S tube, which then became the metal J-tube.
My S had the original plastic style, and the plastic was long gone.
Old 03-20-2013, 07:43 PM
veleno
veleno's Avatar
I tried searching for it on different sites and could not find it (Pelican, Paragon, DC, Vertex, Zims). Does anyone have a part number for the J-tube?
Old 03-22-2013, 03:32 PM
Der Treiber
http://www.autoatlanta.com/porsche-p...-91/103-07.php
http://www.paragon-products.com/J-Tu...105.167.07.htm
Old 03-22-2013, 07:54 PM
veleno
veleno's Avatar
Thanks Der Treiber!
Quick Reply: chain pad tensioner, which to get, zims vs. vertexauto
