WTF are These For?!?!
While replacing my ISV I noticed two connectors that don't seem to plug into anything. This one here was under the intake manifold next to the TPS and DME coolant temperature sensor connectors:
This one here is behind the fuel rail:
Also, where does this bracket go?
What year and model is your car? The one under the intake is probably for a knock sensor (if the car is a turbo). The one on the end of the valve cover is for a diagnostic tool the dealer had many moons ago.
Proprietoristicly Refined
Put it back. Porsche used a common harness for various models and options on the 944 series.
Look under your dash and count the number of empty plugs that go nowhere.
Next to the 3 prong plug (picture) by the rear cam housing there was an exhaust analyzer tube--do you still have it?
J_AZ
J_AZ
J_AZ
J_AZ
There is a spot reserved in hell for the person that designed this intake manifold
That too, but getting the intake manifold on/off is worse than that mess in my opinion.
Any thoughts on that bracket? I hate when I put stuff together and I have left over pieces
The first plug is for the early Air Auxiliary Valve. On later cars it is left unplugged.
The second plug is a diagnostic port, as Van said.
And the bracket mounts to the AOS, just as Jwade described.
I hope that helps!
I hope that helps!
