:: ECS Tuning :: The Ultimate Timing Belt Kit
#33
hmm, anyone else have feedback with this kit. 2 so far in this thread and both have missing parts. i only ask because of my location and it is my daily driver.
#34
This is a little bit more info this "kit".
I placed an order for the kit and just got stuck during re-assembly due to sloppy parts selection by ECS.
The car is an 87 924S, the water pump that was on the car was old style.
ECS sent a water pump labeled as 951, but was a hybrid from the rebuilder. The snap ring to thermostat sealing surface was 4.5mm (old style). The Turbo nozzle was included instead of a Blocking Plate.
The Thermostat and seal included was 944 106 019 00 instead of 944 106 129 05 which would be used on the 4.5mm snap ring depth.
The belt guard was not included in the kit, so I'm out for that too.
When I called ECS they asked what the problem was, so I started to explain. Then he cuts me off to send me to someones voicemail for help with an exchange.
The belts, tensioners, and idlers were all correct.
Jonathan at ECS has helped work out the issues with this kit.
#35
Former Vendor
PM Sent or you may contact me directly at jcrabtree@ecstuning.com and I will get everything worked out for you.
