'91 S2 Injectors - rare bird!
Hey, been a while. I'm usually on the ever-shrinking e-mail list. But I still have my '89 Turbo S and the '91 S2 Cab.
And the latter is the rub. Anyone out here source a '91 S2 fuel injector lately? Or rebuilt them? I have an intermittent miss, usually occurs right after starting the car (hot or cold) or after a WOT/heavy-throttle run. Goes away by the time I stop the car and/or pull one spark plug wire at a time. It's not the distributor cap or rotor, spark wire, or spark plug (all are un-fouled, so it's not flooding a cylinder). So I'm suspecting an intermittent injector that only fails when/after being asked to run a longer duty cycle. Maybe the actuator overheats or who-knows-what.
BUT - '91 seems to be the bastard year. Bosch part number 0-280-155-003, Porsche 944-606-120-00. Dealer says backordered from Germany, $812 each. Confirms what I've found here in the forums in (very few) old posts. Sooooo . . . anyone have a better source? Or a recommendation where to rebuild these? Anyone deal with this recently?
(I'm afraid if I pull and send them out, they'll find one bad one they can't rebuild and I'll be out of a car for weeks - but I wanna take this thing on a 5000 mile tour in 3 weeks. So preferably, I'd like to do an exchange or grab a used one!)
Thanks,
O
Thanks,
O
Not to hi-jack the thread but since I also have a 91 S2.....how are the window rubbers (on the outside of the doors) ? If they are still nice I'd be interested.
What color is the car?
I just checked and they have the GB remanufactured injectors for $40 each, they were actually the ones I got, but they do offer the Bosch units for $100 more. I haven't had a problem with the GB injectors for the two years they have been installed.
The car is titanium metallic color. I will take some pics of the window rubbers and PM them to you.
krazykarl, that ebay listing *says* it's the right one, but they don't look like my OEM ones. Mine are brown, the auction is for green ones. From https://rennlist.com/forums/924-931-...-late-s2s.html, mine should be brown.
Also from another post, 91 injectors should be Bosch part # 0-280-155-003. That's exactly what mine say on them. Unfortunately, I cannot read the digits on the eBay listing. But I'll ask.
944meister, I searched a lot of sites for the re-manufactured ones, and also looked at AutoPartsWarehouse.com. If you put in "1991 S2", it spits out GB part 852-12147 or Bosch W0133-1602513. Unfortunately, if you put in 1990 or 1989 at the same site, they return the *same* injector. Obviously this can't be right (even the dealer I called said it's a unique injector in '91 but wouldn't give me the part #), so I don't trust those sites if they don't distinguish between the 89/90 and 91 injectors.
Why is my stuff always the "special" model? Seems to be the story of my life. (I've been driving 5 different 944s since 1991, so I'm somewhat used to it by now . . . but this one is the oddest!)
Thanks!
Thanks!
The GB injectors I got are brown tops, it would also be good to find out what change was made to the injector for the 91' model year. There can't be much of a difference at all I would think, I know the DME was different with its internal diagnostics, but that's about it.
The 89-90 S2s had ballast resistors and low impedance injectors. The 91 had high impedance injectors and no ballast resistors. You could run the early injectors but you would need to get a set of resistors. An alternative is to get a set of later injectors like the Siemens 44 lb/hr ones and modify the injector constant in the DME maps (easy if you know how).
