Stripped head of Torx airbag screw in side of steering wheel, how to remove?
Old 03-29-2012, 05:33 PM
luftpirate
luftpirate's Avatar
JBweld the bit in?
Old 10-09-2012, 08:45 PM
danny951
danny951's Avatar
Old post but that bolt is a T27... Not T30. I know this because I had the same issue and tried a T27 and it fit much deeper in the bolt head and did the job.
Old 07-02-2017, 08:46 PM
Schnell Gelb
Schnell Gelb's Avatar
My 2002 is T30
Old 07-03-2017, 10:04 AM
931guru
931guru's Avatar
Originally Posted by Schnell Gelb
My 2002 is T30
You have a 2002 944?
Old 07-03-2017, 03:26 PM
Tiger03447
Tiger03447's Avatar
Good for you, Accrorad on the torx trick with the soldering iron. I was going to suggest slotting the head with a dremel and trying to use a standard screwdriver to remove it. Or just oblitering it with a drill bit/s until you could remove the airbag unit. Then remove the remaining post with vise grips or pliers.
Quick Reply: Stripped head of Torx airbag screw in side of steering wheel, how to remove?
